monte12345
Note, this will be a problem going forward for every Windows 11 user because it a fault in a Security Update for Windows 11.
Sunday Nov 2, 2025 I decided to do the 3.0 firmware update for my Zf. So go to the Nikon site and went to the download page for this firmware. Download the file, copy it to a freshly formatted UHS-2 memory card using the Zf to do the format, put the card in the camera and opened up the Firmware function. The screen showed C2.02 and L2.00. Note had the 50mm f1.4 Nikkor Z mounted on the camera.
Repeated this process 3 times from start at the Nikon download page to using a freshly formatted card in the camera with the same Identical Results.
Next I took the memory card and put in in a card reader in my Windows 11 Pro Desktop computer and did a full and complete format of the card using Windows 11 with the Extended FAT32 setting. Learned to things doing this. One is that a full format on a 256mb card takes 15-20 minutes. The second is that you don't actually have to format the memory card in the camera to install firmware. Because the process yielded the EXACT SAME result, a Done Screen instead of the Update Firmware screen.
Next step was to shut the computer down and then do a full reboot of the computer from a cold start, Then downloaded the Firmware Update from Nikon. Followed that up with an in camera format for the memory card, copy that download from a cold started computer with nothing else running except Explorer and got the EXACT SAME results.
Took a break to cool off a bit and did a bunch of google searching with nothing yielded because suggestions to do the install via Snap Bridge or the Nikon Cloud service. Note, will NEVER EVER take that route because a bad firmware install results in a destroyed mainboard in the camera. I will also note that getting Snapbridge to connect to my cameras only works about 1 in 10 times. If I want to change the camera linked to Snapbridge that usually takes up to 45 minutes to accomplish and the WIFI connection is usually closed within 5 minutes. BTW don't know if its the Phone or Snapbridge doing the disconnect but as a result I have concluded the only thing Snap Bridge is useful for is providing location data. As for the Cloud, not at all interested in the complete loss of Privacy that entails.
After spending some time pondering the problem I got out my Windows 11 Pro Laptop. Nice thing about my Laptop it connects to my home WIFI as soon as you power it up. Got out my USB-3 card reader and plugged it into the Thunderport 4 port on my laptop and went to the Nikon Download Site and got the 3.0 Firmware file. Then formatted the memory card in the camera, copied the new file to the card using the laptop and then put the card into the camera. Go to Firmware, did the right click and UPDATE Firmware showed up immediately. Did the update and all done working perfectly.
After this I did a bit more "fishing" for answers. If I look at the firmware file downloaded using the Desktop using a Right Click a menu come up with a line showing Properties. Click on Properties and then go to the Attributes line and the Desktop download shows an attribute of AE. Do the same with the file downloaded by my Laptop and the attribute is A. Further searches on Google shows that Windows 11 is capable of altering the Attribute of a file as it's being downloaded.
Following is an explanation of what is going on.
Solutions. I called Nikon USA about my issues and they were not aware this is a potential problem. Talking with the Tech at Nikon I suggested that providing a Zip file for the updates to act as an "insulator" for Windows Tampering. She thought this was a workaround that may provide a solution and also relayed that up the chain. Anyone who is having issues with an update for any of the Nikon Z cameras should take the time to call Nikon USA and request that the technician email the update file to your computer using a Zip file. She said that was something that she can do if it's necessary. At some point I'm hoping that Nikon will start offering Zip file Downloads for every product.
Hopefully at some point Micorsoft will issue an update to correct this issue but who know then that will happen. At some point Nikon will be getting a stampede of calls about updates that won't work.
