keano12
Leading Member
I know how to work ISO, Shutter and Aperture. Thing to me is that I tend to view ISO as a global brightness. It makes the whole image brighter. Is this simple analogy close enough the way I view it?
Just to understand you better, what would be non-global brightness? Unless you are burning or dodging, most setting affect the whole image. ;-)I know how to work ISO, Shutter and Aperture. Thing to me is that I tend to view ISO as a global brightness. It makes the whole image brighter. Is this simple analogy close enough the way I view it?
In simple terms, yes.I know how to work ISO, Shutter and Aperture. Thing to me is that I tend to view ISO as a global brightness. It makes the whole image brighter. Is this simple analogy close enough the way I view it?
I'm sorry maybe I'm wording wrong LOL. What I mean is if I am using a flash and increase shutter speed the background gets darker and area ivy flash stays the same but ISO increases all light.Just to understand you better, what would be non-global brightness? Unless you are burning or dodging, most setting affect the whole image. ;-)I know how to work ISO, Shutter and Aperture. Thing to me is that I tend to view ISO as a global brightness. It makes the whole image brighter. Is this simple analogy close enough the way I view it?
It is a very good analogy. Shutter speed and aperture change the captured image , motion blur, depth of field and sharpness.I know how to work ISO, Shutter and Aperture. Thing to me is that I tend to view ISO as a global brightness. It makes the whole image brighter. Is this simple analogy close enough the way I view it?
Right that I got. Cool thanksIn simple terms, yes.I know how to work ISO, Shutter and Aperture. Thing to me is that I tend to view ISO as a global brightness. It makes the whole image brighter. Is this simple analogy close enough the way I view it?
However, you need to also be aware that because of the way ISO is implemented in the camera, as you increase ISO (keeping the same shutter speed and aperture), the brightness increases, but also the noise in the image increases. So, if you have the choice, the best image quality is normally achieved at the base ISO.
In other words, it is often better to increase the shutter speed or increase the aperture (decrease the f-number) instead of increasing the ISO.
Yes. And No?I'm sorry maybe I'm wording wrong LOL. What I mean is if I am using a flash and increase shutter speed the background gets darker and area ivy flash stays the same but ISO increases all light.Just to understand you better, what would be non-global brightness? Unless you are burning or dodging, most setting affect the whole image. ;-)I know how to work ISO, Shutter and Aperture. Thing to me is that I tend to view ISO as a global brightness. It makes the whole image brighter. Is this simple analogy close enough the way I view it?
So if my flash was struggling outside I could increase the ISO to make it easier for the flash.
This thread could max out but increasing ISO does not increase the nosiness. The reason for higher ISO is because there is not enough light, and less light means more noisy image. ISO makes it simply brighter at the rendering level. At the signal acquisition level, "ISO dial" plays additional functions.In simple terms, yes.I know how to work ISO, Shutter and Aperture. Thing to me is that I tend to view ISO as a global brightness. It makes the whole image brighter. Is this simple analogy close enough the way I view it?
For those who are determined to be obtuse, increasing the ISO increases the visibility of the noise in the darker parts of the scene by brightening those parts (along with everything else in the image).This thread could max out but increasing ISO does not increase the nosiness. The reason for higher ISO is because there is not enough light, and less light means more noisy image. ISO makes it simply brighter at the rendering level.
FWIW, I'll agree that higher ISO increases the visibility of the noise in the darker part. Similar effect occurs when the shadow is boosted. I have not thought of that as increase of noise but certainly would not disagree that higher ISO makes noise more visible. I think it's a good point.For those who are determined to be obtuse, increasing the ISO increases the visibility of the noise in the darker parts of the scene by brightening those parts (along with everything else in the image).This thread could max out but increasing ISO does not increase the nosiness. The reason for higher ISO is because there is not enough light, and less light means more noisy image. ISO makes it simply brighter at the rendering level.
For practical purposes, this means that noise may become obvious at high ISO that was less much less visible at low ISO.
I suspect mostlyboringphotog already knows all this, but just wanted to show how smart he is.
I'm also sure he'll start throwing abuse at me for pointing this out, but I do not intend to respond further! This topic has been fruitlessly argued over many times in the past.
Right but irrelevant because what matters is the SNR (or NSR).For those who are determined to be obtuse, increasing the ISO increases the visibility of the noise in the darker parts of the scene by brightening those parts (along with everything else in the image).This thread could max out but increasing ISO does not increase the nosiness. The reason for higher ISO is because there is not enough light, and less light means more noisy image. ISO makes it simply brighter at the rendering level.
Not really because for practical purposes, our high ISO photos do not look brighter.For practical purposes, this means that noise may become obvious at high ISO that was less much less visible at low ISO.
Thank you for a more gracious reply than I expected (or probably deserved)!FWIW, I'll agree that higher ISO increases the visibility of the noise in the darker part. Similar effect occurs when the shadow is boosted. I have not thought of that as increase of noise but certainly would not disagree that higher ISO makes noise more visible. I think it's a good point.For those who are determined to be obtuse, increasing the ISO increases the visibility of the noise in the darker parts of the scene by brightening those parts (along with everything else in the image).This thread could max out but increasing ISO does not increase the nosiness. The reason for higher ISO is because there is not enough light, and less light means more noisy image. ISO makes it simply brighter at the rendering level.
Well, I think Standard Deviation reflects the noisiness of the image file better than SNR.Right but irrelevant because what matters is the SNR (or NSR).For those who are determined to be obtuse, increasing the ISO increases the visibility of the noise in the darker parts of the scene by brightening those parts (along with everything else in the image).This thread could max out but increasing ISO does not increase the nosiness. The reason for higher ISO is because there is not enough light, and less light means more noisy image. ISO makes it simply brighter at the rendering level.
Consider an M mode with lower ISO and higher ISO...Not really because for practical purposes, our high ISO photos do not look brighter.For practical purposes, this means that noise may become obvious at high ISO that was less much less visible at low ISO.
You see above that brightness can be used to explain the visible noise too .Thank you for a more gracious reply than I expected (or probably deserved)!FWIW, I'll agree that higher ISO increases the visibility of the noise in the darker part. Similar effect occurs when the shadow is boosted. I have not thought of that as increase of noise but certainly would not disagree that higher ISO makes noise more visible. I think it's a good point.For those who are determined to be obtuse, increasing the ISO increases the visibility of the noise in the darker parts of the scene by brightening those parts (along with everything else in the image).This thread could max out but increasing ISO does not increase the nosiness. The reason for higher ISO is because there is not enough light, and less light means more noisy image. ISO makes it simply brighter at the rendering level.
So Nikon engineers made a mistake by making ISO 800 hardware based instead of pushing ISO 100 by 3 stops?In Canon world it is exactly as you described. In the other sensors increasing ISO is worse than keeping the ISO down and then brightening the resulting RAW in PP.
If I use Nikon D7200 at ISO 100 and the photo is underexposed 3 stops I get better results for noise in PP brightening than making the same photo at ISO 800 (so 3 stops).
It's a bit more complicated, the problem is the linearity in the deep shadows and black level drifting; IMHO ISO 400 and ISO 800 are a bit more stable than 3200, and much more stable than ISO 100 (processing on all - white balance from second grey, rather crude, linear brightness adjustment, no colour transforms, no anything else). If you want TIFFs, let me know and I will process and upload.So Nikon engineers made a mistake by making ISO 800 hardware based instead of pushing ISO 100 by 3 stops?
See this, think of this as the situation you describe but both shots are pushed 2 stops more. The colors change when you shoot at low ISO. You may argue that you do not see much difference but to claim that it is better, except for the non-clipped highlights, is a big stretch.
Wait a minute, I'm horrified with underexposure of more than 2 stops on any camera, and on my Nikon Df or D5 I'm horrified of not setting ISO right tooThe friends that have Canon sensors are horrified by underexposure and recovering shadows.
