Pretty much right. There is a depth-of-field issue too.I get it now, there is no substitute for actually moving if you
want to change in perspective. Zooming is simply cropping, the
advantage being simply more pixels and nothing else (assuming a
perfect zoom lens)
I dunno - give me time to reflect.You can get a different perspective without moving. See if you
can figure this one out:
Lee Jay
(see profile for equipment)
Reflect some more. ;-) That shot has an AOV of around 90 degrees and was shot with the 100/2 on the 20D. The effective location of the shot was on the other side of an opaque wall.I dunno - give me time to reflect.![]()
There is no direct answer to this question without out including the final print/projection size/format.If I want to capture what you "see" then what type of lens?
Zooming changes only the magnification of the image.
Moving the camera relative to the subject changes the perspective.
What people consider a change in perspective from only a change in
focal lenght is NOT perspective change, pure and simple.
Vocabulary-challenged photographers sometimes call it "apparent
perspective" or "compression". But changing focal length from
fixed position while enlarging/reducing to keep constant image size
on output medium proves that focal length it is only a
magnification change, not a perspective change
That is why knowledgable photography instructors tell their
students to avoid relying on zoom lens; they tell them to MOVE
to/from/around the subject to get different perspectives.
There is no doubt that changing focal lenght is important; most of
my own lenses are zooms; but I use the zoom for filling the frame
the way I want AFTER I have changed perspective by moving the
camera relative to the subject.
[email protected]
Good advice.I use the zoom for filling the frame
And the answer is...So my question is...
Is Zooming in EXACTLY the same as physically moving closer to the
subject? Or is there some price to pay for being lazy and using
the Zoom ring instead of actually getting up and walking closer?
And the conventional wisdom is correct. More precisely, it is the field of view captured in the print that matters, rather than the lens itself. This means that if we consider different formats, the 35mm equivalent focal length should be used; and that if we crop or stitch, we can make one lens behave like a different one.I recall in a previous thread some discussion about the change in
perspective one gets from Zooming in. In short, conventional
wisdom says that image depth flattens as one increases focal length.
As explained above, this is not the case. Moving closer to the subject changes perspective but does not introduce distortion!An arguement was made that this "flattening" is not a result the
lens "distorting" perspective but rather, it is the exact same
effect as moving closer to the subject.
You are totally confused and don't have a clue as to what you're talking about.And the answer is...
Zooming in produces telephoto compression (the "flattening" effect
you describe)
