with your light meter, although learning to use histograms and your camera's reflected light meter further streamlines the process of balancing ambient light with flash. The lighting below was achieved without a single photo being taken to test it. How?
Equipment: Canon EOS 5D Mark II + EF 100/2, Minolta AutoMeter IV, Nikon SB900 fired through 18" x 18" softbox in Manfrotto stand powered by Quantum Turbo SC battery.
Process:
1) Scout suitable background based on anticipated subject position (has to shoot in a crowded corridor), desired aperture and degree of background defocus desired.
2) Position stand-in subject at subject position, compose image, then meter the background using the camera's spot metering, positioning the most important highlight at +2 1/3 EV. Set aperture and shutter speed based on handholdability and DOF requirements (shallow as possible, in this case).
3) Use Minolta meter to measure flash intensity at the subject position, adjusting power output to accommodate (if possible) the desired aperture.
4) Take pictures.
I had this all sorted out before the subject ever arrived. He showed up, I showed him where to stand, and started shooting.
We were done in about five minutes. I never had to fiddle with settings. Knowing what you're doing behind the camera is a great thing. It helps take the stress out of our jobs. I applaud your desire to become proficient with metering ambient and flash light so that you spend less time tweaking and more time thinking about composition or interacting with your subject.
This was shot at ISO 200, f/3.2, at 1/60th of a second. Checked the LCD, yup looked good, then shot.
Had I altered the flashes, or moved them, I would need to compensate for that - again, the point is to spend less time fiddling, and more time shooting. I believe the light meeter will help me in that endeavor.
you start at f8..if it is too dark, try 5.6 or lower...or jack up the iso..
now that you have figured out where to start with the light meter, put it aside and start shooting..
you don't need that anymore...
and keep in mind....if you measure the light the "correct" exposure may or may not be read on the meter..you have to look at the lcd..
which is were you were when you started..
Kabe Luna
http://www.garlandcary.com
