You're quite right, it should be repeated. And disected. I
especially enjoy this section, where the JCIA talks about pixel
counts in a multiple sensor or multiple color plane camera.
b) For DSCs that use a plurality of image sensors, the number of
image sensors and the number of effective pixels corresponding
to each image sensor shall be noted. If the total number of
spatially sampled pixels is also noted, the description should
clearly state that the noted number is the total number of
effective pixels corresponding to all of the image sensors, to
avoid consumer misunderstanding.
This is relatively clear. If you've got multiple planes, you tell
the consumer how many planes you've got, and how many pixels are on
one plane.
The Foveon adds their interpretation of this:
This rule for three-chip cameras suggests that only
pixel sensors on a single chip should be counted, so the
"total number of spatially sampled pixels," or total
number of photodetectors on an X3 sensor,
could be used as the number of effective pixels."
The only problem is that the layers of sensors on the Foveon are
spatially aligned, so that there are indeed just 3.4 million
"spatially sampled" pixels, with three photodetectors per pixel.
This is the authorative argument which should end this issue once
and for all. Foveon says their sensor is 3.4 megapixels.
Ciao!
Joe
http://www.swissarmyfork.com
