Sorry to disagree with David, but IE is not a color space aware
application, hence the need to convert images to the sRBG color
space before posting. You also need to be aware as other posters
have mentioned that there is also color space to contend with along
with color mode
Just what I said, IE is not colour space aware and you can quite clearly see the difference between pictures saved in different colour spaces in it. See
http://forums.dpreview.com/forums/read.asp?forum=1021&message=18650461
where I posted the same picture saved in Nikon Wide, AdobeRGB and sRGB.
Just to quote the manual:
Color mode I = Flat colors for portrait and other work - Color
Space sRGB
Color mode II = Ehanced color gamut - Color Space Adobe
Color Mode III = Enhanced Green & Blue - Color Space sRGB
The manual is also pretty clear that Color Mode II and sRGB is not
a valid combo. So unless you are doing some work that requires the
increased color gamut(and even that has been debated) like
landscapes or commercial work, Color Mode II is probably not a good
option.
So given your workflow and subjects shooting in Color Mode I would
work fine as your subjects really are the swimmers and you want to
get those tones right and in an appropriate color space, sRGB, for
people to post and email around.
Personally I stick to AdobeRGB/mode II and convert to sRGB for the web (I don't change mode though). Nikon's explanations of modes I, Ia, II, III, IIIa are less than clear.
This is what it has to say in the Nikon Capture help pages:-
Color Mode
Choose a color mode for fine control over chroma, brightness, and color gamut, much as you would choose different kinds of color film for different scenes. Choose from Unchanged, Mode I, Mode II, Mode III, Mode Ia, or Mode IIIa, or B&W. In the case of images taken with the D1, Unchanged is equivalent to D1 Mode (NTSC). Color mode selection is available only in the case of RAW images taken with D1-series, D2-series, D200, D100, D70s, D70, or D50 cameras.
It amplifies this as follows:-
If "Use this instead of an embedded profile when opening files" is selected for Default RGB color space in the “Color Management” tab of the “Options” (“Preferences”) dialog (Windows Detail, Macintosh Detail), the default RGB color profile will be used as the working color space for all images, regardless of the mode selected. If "Use this instead of an embedded profile when opening files" is not selected, Adobe RGB will automatically be chosen as the working color space for Mode II images. The working color space for Mode I, Ia, III, and IIIa images will either be the color space selected with the camera (D2X and D200 only) or sRGB (all other cameras). The working color space for NTSC images (D1 only) will be NTSC. Modes I and Ia, which are adapted to the sRGB color space, are suited to portraits that will be printed or used “as is” with little or no modification. Mode II is adapted to the Adobe RGB color space. This color space is capable of expressing a wider gamut of colors than sRGB, making it the preferred choice for pictures that will be extensively processed or retouched. Modes III and IIIa, which are adapted to the sRGB color space, are suited to nature or landscape shots that will be printed or used “as is” with little or no modification.
It is fairly clear that the modes are meant to be fine trims on the working colour space and you are right that modes I, Ia, III and IIIa are designed to trim the narrow sRGB gamut rather than the wider aRGB
Dave
http://www.rosser.pwp.blueyonder.co.uk
http://www.pbase.com/dgrosser
