Last month marked the 10th year I’ve had my HS50EXR and I started thinking perhaps it’s time to replace it. But after looking, reading and asking questions, I’ve decided to keep the old s.o.b.
As so often happens, a couple of years ago the camera went through the sticky body syndrome. I tried a couple of the suggested remedies found online but ultimately just kept using it as is. Now the surface isn’t sticky. Maybe it’s dried up some. Certainly, by looking at it, you can tell it’s picked up a lot of dirt, dust, etc. and I’m sure that helps. Doesn’t look very attractive but who cares so long as it still works?
That brings me to my two questions:
- A couple of times, the lcd monitor has gone black while in use. I was too far away from the EVF to have caused it. The weather wasn’t a factor; it wasn’t too humid or rainy. I’d close the EVF and usually it’d be fine when reopened although there were times when I’d have to do that more than once. My guess is it’s a problem with the ribbon cable. Has anyone encountered this and what possible solutions might there be?
- The rubber piece on the body where one’s thumb rests has started to detach itself from the body. I’ve cleaned out the old adhesive and used Scotch 924 tape (a.k.a. snot tape) with limited success to try holding it in place. Any suggestions?
