If the light was a challenge and you couldn't shoot a bracketed sequence the only option is PP the .JPG selecting the white from the sky and tranforming it in a light blue. Hope you don't mind if I played a little with your pic.
By that I mean selecting the metering mode that's appropriate for what you're trying to meter and/or selecting Active D-Lighting(if shooting jpeg). The differences between whatever the D5100 does and what the D7000 are not going to be so much in exposure rather than post processing. If you shoot raw and post process the image yourself, you can tone map it the way you want rather than the way the camera thinks you want it anyway.Can you explain the "Configured Correctly" part of your comment? I just bought a D7000 and I'm really curious why it blows out highlights when the D5100 doesn't. Features and body wise, the D7000 is exactly what I want from a camera, but I don't understand why the lesser D5100 seems to do a better job of exposure.The reason you got darker skies in that photo is because the scene is mostly sky. Configured correctly, a D7000 would give you the same thing.
Thanks rondhamalam!...
This lesson is to show that ONE exposure is enough to capture all dynamic range.
This is the world, the way I see it: http://twenty200.com
Yes pleasedo you still want it?
Now that sure looks cooked...
If the dynamic range is low it will have no difference between multiple exposure and one-shot HDR, but if the dynamic range is very high the camera can not capture all the tone on the high dynamic range scene.Thanks rondhamalam!...
I like the idea that one shot for HDR pp as it convenient and sometime you don't have the second chance. However, will it give you same level of multiple exposures for HDR shooting?
I don't have comparison ready. I leave this privilege to youIf not would mind give some comparison?
--In CS2 (and 4?)
1) go Image/Adjustments/Shadow-Highlight . To lighten the very dark areas.
Bring up the shadows so tree trunk not so dark. This also lightened the stone walls which I liked.
2)add blue sky. Look at a real blue sky, it is darkest blue high up and fades out at horizon.
The CS2 Gradient Tool is the secret to doing this.
Select the sky. I used the Magic Wand Tool. Other ways/tools will work. Pay attention to how you have Select/Feather set, I used 10 pixels.
Select the sky blue color you like, select the Gradient Tool. Put mouse at top of image, click and drag down to grass. Release mouse - bingo a gradient blue sky, darker at top, evenly fades.
Play with Gradient end point to vary amount of blue at horizon. Change image window size or canvass size to include the very tip-top of the image. Set Gradient Mode to Darken, whatever works best for that image.
cary
--Yes pleasedo you still want it?
At the moment I don't know if there is highlights clipping on the sky in the RAW
One of free large file sharing websites is:
http://www.rapidshare.com
thank's in advance
Take into account that Nikon had 6 months to work on the D7000 in order to set the D5100 parameters.
I've taken 5000 pictures with the D7000 and it always gave me pretty white skies.
The D5100 yields a much darker jpeg in order to prevent clipping the sunny highlights.
You're welcome. Photoshop is wonderful, thank you God for giving it to usthanks so much....will give this a try when i can find the time![]()
Thank's for the RAWmessage sent with link to nef file. i wont be back on pc for a while so will deal with it later if the link is not valid or just does not work etc
