Thanks. Adjusting your camera-holding a bit is perhaps the smallest price to pay. And if that was a panacea (it is a help but not a full solution), my complaints would be minor. Hopefully, though, the whole problem will disappear in a not very distant future, thanks to the appearance of a rolling electronic shutter (Pany bodies already have that), a first-curtain electronic shutter (some Sony and Canon cameras already have that), and eventually a global electronic shutter that can replace the mechanical shutter altogether.Excellent post and thread!
It's just sad to see that we now have to resort to holding the camera in a specific way to make the best of the fantastically sharp lens.![]()
Come on your making that up.Take some hand held shots between 60th and 160th of a second and magnify the images at 400%. Check for vertical ghost images. This is best tested with very fine and contrasty horizontal lines in your test motive. Power lines against the sky work well and you should use a longer focal length like the 45/1.8
http://www.flickr.com/photos/lighthunter_de/
The search engines have nothing on "Shutter shock"
Beaten to death since at least a year. I guess the main reason why it keeps popping up is the steady flow of newcomers who are not yet familiar with the content of past discussions.A search for 'shutter shock' in DPR returns 87 News and Reviews results, 8,037 forum posts and 1 member called 'shutter shock'.
It is a well thrashed subject.
I am not sure that anyone (except, possibly, the manufacturers) has a really good answer to that question I am afraid. But I personally don't believe that, as a rule, there is any copy-to-copy variation to speak of with regard to this problem. Furthermore, I think I have never seen a report from some user who sent the body for repair or had it exchanged based on shutter-shock issues who found that the problem was fixed after repair/exchange. So by and large, I would say it's a design issue whose impact depends on the lens used and user technique/ability with regard to hand-holding. How much of a problem you see is additionally likely to depend on how picky you are with regard to sharpness and how carefully you test.related to individual units. I understand how there can be variability between individual units, but, for example, my testing of my camera I don't see ss (e-m1). but we could not rule out that It could be a problem for other e-m1 units. I guess the question is then would ss be design issue, manufacturing issue, user technique, or a combination all?
Tested my E-M1 using a focus target chart and as I suspected there is no problem whatsoever. Perhaps other cameras have the problem but I remain skeptical given the testing methodology I've seen being used by others.
I went to the blog you cited which claims to have established shutter shock with the Oly 75-300 at all shutter speeds between 1/100 - 1/200. Though I knew what the results would be, I wasted my time taping newspaper up and took shots using that lens both handheld and on a tripod. Guess what? All the shots looked like this:Excellent post and thread!
You need to work on your observational capability. Blur due to lack of focus does not look the same as blur due to camera shake. The blog you refer to, i.e., thisI went to the blog you cited which claims to have established shutter shock with the Oly 75-300 at all shutter speeds between 1/100 - 1/200. Though I knew what the results would be, I wasted my time taping newspaper up and took shots using that lens both handheld and on a tripod. Guess what? All the shots looked like this:Excellent post and thread!
Oly 75-300 on tripod
I did, however, run into one problem. I don't have the same setup in aperture priority as I do in shutter priority. In aperture priority I can easy separate focus. In shutter priority I use the half press method. Guess what? When using shutter priority the camera tried to reacquire focus, couldn't lock it, and gave me this mess:
Shutter priority --> no focus --> horrible mess
Now, the site you think is so great at establishing shutter shock may have gotten the world's worst copy of the 75-300 lens OR the world's worst copy of the E-M5 OR both. But when I'm looking at the results they look a lot more like a lack of focus than shutter shock.
All I can tell you is that the E-M5 and E-M1 allow me to shoot at slower shutter speeds than my Canon bodies using L stabilized lenses and that I have never experienced shutter shock in the four or five years I've been shooting the m43 bodies. Given this experience, I don't see any foundation for your complaining about how you have to go through any special gyrations to get sharp shots with m43 gear.
you'd notice that I took a series of shots between 1/100 and 1/200. I just didn't want to waste bandwidth by posting stupid shots of newspapers which showed .... nothing. Using EXACTLY the same lens and camera as he did I can't even begin to reproduce what he shows.also, that pic is at 1/200. try it at 1/40, 1/60, 1/120
Ha ha. The point is that I can't begin to reproduce the mess he gets unless I really work at it. I'm sure if I tried to take a blurry photo I could do that, but it's not happening under the conditions and with the same equipment he says he used.shows blur due to camera shake. What you show is blur due to lack of focus. An important difference is that blur due to camera shake is typically stronger in some directions than in others. When it is due to shutter shock, the direction is predominantly vertical (when shooting in landscape orientation). As you can see, the example in the blog shows far more blur vertically than horizontally whereas your example does not.
DonSC wrote
so what's your point? your camera either has little or no blurring at said shutter speeds, congrats..Ha ha. The point is that I can't begin to reproduce the mess he gets unless I really work at it. I'm sure if I tried to take a blurry photo I could do that, but it's not happening under the conditions and with the same equipment he says he used.
I'm not sure where the 9mm and 1/250 come from. The web site says: I mounted the camera/lens unit on a tripod, set the focal length to 300 mm and made a sequence of exposures from 1/8 sec to 1/400 sec. Settings were IBIS off, Timer delay at 2 seconds. There was clearly apparent blur with double imaging from 1/100 - 1/200 sec.no way diffraction can explain this. and at 9mm and 1/250, hand shake would be close to impossible...
what we could be seeing is a less severe problem in yours? it's hard to deny there's something going on at 1/40 and 1/60, which had even escaped your eyes. nonetheless it exists
in summary; two other people separately claimed to have almost identical issues. but you go out and test in the same situation as both of them and find no problems. plus one of them gets a replacement camera, finds the exact same issue. if i were you i'd just count my lucky stars.To try and reproduce this I simply used the 75-300 at 300mm and shutter speeds between 1/100 and 1/200 which is the shutter speed he said produced the double imaging.
Another poster uploaded a blurry photo which he said was produced when using the Oly 9-18 lens on an E-M1. Since I have that lens, I went out and, using the 9-18 lens and the same shutter speed he used, tried to reproduce his result. My shot, which I posted a couple of hours after he posted his, was in focus and showed no double imaging or blur.
I am afraid the laugh is all on you. Clearly, you don't know how to test things, nor how to evaluate the results. Just the fact that you shot your test at ISO 3200 says it all really.Ha ha. The point is that I can't begin to reproduce the mess he gets unless I really work at it. I'm sure if I tried to take a blurry photo I could do that, but it's not happening under the conditions and with the same equipment he says he used.shows blur due to camera shake. What you show is blur due to lack of focus. An important difference is that blur due to camera shake is typically stronger in some directions than in others. When it is due to shutter shock, the direction is predominantly vertical (when shooting in landscape orientation). As you can see, the example in the blog shows far more blur vertically than horizontally whereas your example does not.
