I've been messing around with different macro flash setups, including designing various diffusers. As I test them out, it does seem anecdotally that some designs eat up more of the flash's light than others. I'm looking for a way to quantify this to better compare and refine my designs.
So far I've just tried out smartphone light meter apps, but those have come up short. The best one was an iOS app called "Light Meter" that did a great job of roughly measuring ambient light in the room, flashlights, etc. But none of my camera flashes registered. I suspect it's because the sampling rate of the app just didn't light up with the super-quick flash of a camera flash.
Would a regular inexpensive light meter, like are all over Amazon, work for this? I don't want to spend money on this kind of device just to find out it has a similar sampling rate problem as the apps.
What I'm NOT looking for is a traditional photography light meter, that measures the ambient light and tells you what camera settings to use. And I know I can manually adjust the power of my flash with different setups. I still want to know how different diffusers affect output in some objective way.
I don't need the measurements to be totally accurate either, which is why I first looked at smartphone apps. I just need something better than my subjective sense of brightness.
I appreciate any help you all can provide. Thanks in advance!
