Pierre Lagarde
Leading Member
You're confusing : Electronic Shutter (so ES) is not EFCS. Auto shutter mode is choosing between EFCS and mechanical, not between ES and mechanical.If there was enough light during concerts I would use faster shutter speeds. But since that's not the case, to keep ISO as low as possible, I photographed most of the shows with 1/200 or 1/250.I'm sorry, but I'm not sure to get your issue. On one hand you say you want to use high speed shutter for action and on the other hand you say you don't.Trying to keep ISO's al low as possible when photographing concerts I start at 1/200. Based on the amount of action on stage I might shorten or lengthen the shutter speed. But 1/200 should be fast enough to prevent blurry images caused by 'shutter shock'.I think you should reread the thread. I and others explained that if you set the shutter mode to Auto, mechanical shutter is always chosen above 1/320s.Why impose these limitations on photographers who plan to shoot with faster shutter speeds to photograph sports or action?The answer is in the article you mentioned:All Nikon Z6 and Z7 models (Z6, Z6II, Z6III, Z7 and Z7II) have a mechanical shutter.
With Custom Controls setting for Shutter Type (d5 or d6, depending on the model) you have several options to choose the shutter type to be used:
The camera's default to "Auto" and that in turn determines which shutter type is used based on the shutter speed.
- Auto
- Mechanical shutter
- Electronic front-curtain shutter (EFCS)
- Electronic shutter (only on the Z6III)
The manual also states that the option "Mechanical shutter" is "not available with some lenses".
I found a list of lenses with shutter type limitations:
https://www.nikonimgsupport.com/eu/BV_article?articleNo=000066929&configured=1&lang=en_GB
The closest you can get to using a mechanical shutter when using one of these lenses is setting the shutter type to "Electronic front-curtain shutter".
But I'm not sure if this eliminates the risk of banding in environments with LED lights, like the mechanical shutter would.
Why did Nikon impose such limitations to their camera's and glass?
Their DSLR's never had those limitations and worked fine for me. ...
When the following lenses are mounted on Z series cameras, the 'Mechanical Shutter' option will be unavailable in the 'Shutter Type' menu option.
This specification is designed to mitigate mechanical vibration effects that occur when shooting at slower shutter speeds.
My point is, that in the old DSLR days the vibration of the shutter was the least of your worries when photographing long(er) exposure. The movement of the mirror was more of an issue than the movement of the mechanical shutter (the only shutter available at the time).
And when photographing sports of fast action with (much) faster shutter speeds the 'shutter shock' is not an issue.
It feels like that. And feelings matter.It's not the case.I've photographed concerts with DSLR's without stabilised sensor and with lenses without VR and had no issue getting sharp photos.
Why patronise me by not allowing me to use the mechanical shutter and forcing me to use electronic front-curtain shutter.
Why not let the photographer choose how he or she wants to use the camera?
Why impose these limitation on the newer S glass (like my Z 24-120mm f/4 S) and not on the older Z glass like the 24-70mm f/4 S of Z 14-30mm f/4 S?
It makes no sense
With Auto mode, camera will choose between Mechanical shutter or EFCS. TBH, I don't see what can be the problem with this behaviour in the situations you're describing.
Maybe you should describe more precisely your sets and different situations (what lens for what purpose) in order to readers here to better understand your issue.
With those shutter speeds, when shutter type is set to Auto, the camera will use the electronic shutter and this increases the risk of banding when photographing artist lit by LED stage lighting.
Another unpredictability is the frames rate associated with the shutter type. The electronic shutter maxes out at 20 fps, the mechanical shutter at 14 fps. The 14 fps is is more than I need (10 fps is the sweet spot for me), but that too is out of my control with shutter type set to "Auto".
My point is: I want more control than just setting shutter type to "Auto".
EFCS have much less problems than ES on most cameras, but perhaps some differences in bokeh at faster shutter speeds which is not a problem as Auto shutter mode precisely switch to mechanical shutter for those faster shutter speeds. So you won't likely see any difference in results between EFCS and mechanical at lower shutter speeds, and so, you don't have to worry about it.
If you want to know more about the differences between ES, EFCS, mechanical shutter, I encourage you to read this article on Photography Life :
https://photographylife.com/mechanical-electronic-shutter-efcs
If ever it can help too, my own experience is that, in concerts, I usually use F/2 or F/2.8 lenses and expose with Highlight-weighted metering because of spotlights, and also use(d) short teles to 300mm lenses, and more than 1/200s at distance to avoid motion blur and fix musicians movements. Modern cameras allows the usage of higher ISOs + Highlight-weighted metering allows to avoid over exposition of lights and lower ISOs, BTW.
I already was doing this with DSLRs and never had problems with results.
As well, there is no relation between shutter mode and release mode, unless too slow shutter can slow down your burst, of course : may it be ES, EFCS or mechanical shutter mode, chances are that you can perfectly set your release mode to any burst rate available on your camera, including 10Fps - if it's available.
Once again tell us more about your set and usage : what camera, what lens in what conditions ?
