The issue is that if you do not have a (newer) SUPER-HIGH frame-rate (aka 20/30fps), then you HAVE to rely on a (well timed) single shot, (and I am not denying you are indeed skilled with these very good shots).
However ... if you indeed do have a 20/30fps then you can capture (possibly) even better shots, (because the above are still only "guesses" of the "peak" -- where you "anticipated the peak").
Conventional (high) frame-rates were simply not fast enough to allow what is now possible (w/ 20/30+fps).
But I repeat those are excellent shots above.
Anyone can post Random shots and claim they were the decisive moments. Hence the problem. Ask someone to go out on a given today for a exact set of moments, then you see what they can or can't do.
I have shot sports and dance single shot for many decades. Look through my gallery for examples. Surprisingly it is not magic. Mostly it is practice and anticipation which are simple skills that can usually be acquired.
Tony, I repeat again that those are excellent shots.
But do you deny that if they were instead shot @ 20/30fps, you could potentially/probably have selected one (or even several) that could be better ???
No matter how well timed you think you are, (and I am very-good/
excellent also), they are still (educated) "guesses" of the "best" timed. No matter how satisfied I may have been in the past, I am not vain enough to not concede they could potentially have been even better.
There are also things like lighting and birds starting to fly that are impossible to "anticipate", (aka "Anticipate The Action") only
Pre/Pro-Capture can capture spontaneous events.
Also, think of a football player running to catch a pass. Is the best shot of the (running0 player as he is looking back at the ball approaching, -or- maybe a split-second later when the ball is 'inches" from his fingers, -or- a split-second later when the ball is firmly in his hands (with his head still looking back where the ball camera from), -or- when he has tucked his hands/ball to his chest and now looking toward the goal, -or- OOPS ... he is now being grabbed tackled and an entire new series of "best" possible shots start.
With single shot, (or even conventional "fast" fps), was NOT fast enough to allow possibly 5 or 6 usable/sellable shots from those (closely-timed) sequences.
Both the newer (20/30fps) frame-rates, and Pre-Pro Capture, are a new paradigm for action-photography, (including the never-possible before ability to capture the "peak" of action AFTER the "peak").
Arguing against
paradigm-changing technology is the same as those who argued against built-in & auto metering back in the 60's, AF in the 90's, and more recently MirrorLess cameras.
Remember that the new stacked-sensors also allow <5ms shutter-lag, compared to up to 300ms in (past) dSLR's.
I also don't understand why the reluctance to FULLY-articulating (and reversible) LCD, to enable shooting positions never before (accurately) possible.
