What I found strange is that anybody knows that "digital zoom" on smartphone reduce the quality, but now it seem well accept on a MF camera costing you 5k....
Smartphones start with small sensors and a relatively small amount of light, so cropping makes that already small sensor even smaller and ends up exacerbating problems that are already there. Whereas if you crop in from a 100MP GFX sensor, you’re still looking at a 60MP full frame sensor or a 30MP APS-C sensor, both of which are competitive with top end cameras that produce stunning results. It works because a big 100MP sensor is total overkill for the needs of most people who’d contemplate buying a 100RF, and that’s not true of a phone sensor.
If the number of pixels is the most important thing and cropping in from this sensor is somehow unacceptable, then the Leica Q3 43 must also be unacceptable, because that’s what you get from the 100RF. They both give you a 60MP full frame sensor with a broadly similar field of view. But one of them
also gives the option of using a 100MP MF sensor and a wider angle. And it’s the cheaper one!
It’s short-sighted to think that just because a 100MP MF sensor exists, its sole purpose must be to provide 100MP MF images. Its real purpose here is to do the job of several cameras in one compact and lightweight package, and to still produce thoroughly competent images in all cases.
The way to think about this camera is to consider how many of your own shooting situations it can cover with output that’s more than good enough for the job. Anyone who can only start from the thought of the 100MP on that sensor should buy a GFX 100S II instead.
