Finally thinking of upgrading my A7R after 10 years. I have been using the original A7R with a few Sony GM lenses (24/1.4, 35/1.4, 50/1.4, and 135/1.8) without much trouble. AF is slow but reliable, and the 24mm and 50mm see the most use. I do not shoot that much—shutter count is still under 50k, which is neither low nor high. My current workflow is pretty basic: shoot, check focus, move on. Slow but acceptable.
What I am really looking for now is better Human Eye AF without needing to press two buttons. I am considering the A7RIII, IV, or V. The V is clearly the best, but I am not sure I really need it—since I have been fine with the original A7R, anything newer is already a step up. My usage is moderate.
I also considered the A7C and A7CII, but I prefer higher resolution since I am used to 36MP without an AA filter. At this point, the A7RIV looks like a sweet spot: 61MP, better SNR than my A7R (per DxO), and pricing around $1400–1500—about $1k less than the A7RV. For landscapes and cityscapes, I doubt it makes a big difference except for the A7RV’s focus stacking, which I would not really use.
Do you see any major shortcomings with the A7RIV for streets and portraits? How does the A7RIII compare, since that would reduce the budget even further? Thanks for your thoughts.
