peripheralfocus
Sorry, William. Jono and I had a long back and forth exchange over what the real significance of the so-called focal length "multiplier" is, and I was just joking about starting the whole thing over again.
I don't think you can count this last part -- the light ray angle of incidence issue -- as an advantage for the Olydak. The sensors in currently popular 35mm-based DSLRs are already bigger than the sensor that will be in the Olydak, and there is clearly no significant problem with lower edge illumination -- or light falloff, if you prefer -- on these cameras. Even if 35mm-based camera systems would have problems with some future "full frame" (i.e. 24 x 36mm) sensor, that can't be counted as an advantage for the Olydak because the Olydak (at least as far as we know) won't be able to use a sensor that big either.One thing I didn't found
mentioned is the impact of using lenses designed for digital. Maybe
the point is moot because the 35mm based DSLRs only use part of the
light of the lens. However, at some point as the sensor size
approaches full frame there's going to be issues of light fallof at
the edges. Unlike film a CCD or CMOS sensor need to have the light
entering at close to a 90 degree angle. Digital lenses should
compensate for that while regular 35mm film lenses aren't optimized
for it. I'm not sure if the size of the sensors used in the current
crop of DSLRs is big enough to make it an issue but potentially it
could mean another edge for a 5MP Olydak.
Saw on another board tonight a message from Koo (she used to be an
Oly user) saying that a contact she has told her that Oly will soon
announce a DSLR with six lenses designed to match the sensor. She
says that it is not clear whether it will be a 5 or 6 megapixel
camera.
Now, here's my question...why would Olympus release a 5 mp camera
if they hope to compete with Nikon and Canon? Does this make sense
to anyone? I'm hoping the answer is that it doesn't make sense and
suggests that the camera WILL be a 6 mp.
It sounds more and more likely there IS going to be an
interchangeable lense DSLR from Oly.
Olympus E-10, TCON, MCON, WCON and Fl-40
Gallery: http://www.pbase.com/galleries/cokids
