All the beginner needs to know is that in Auto mode, the camera may adjust Aperture, shutter, ISO, or subject lighting (pop up flash).
... by moving along the path of an exposure triangle...
Pop up flash means moving to a different triangle.
But in any case, why is it important to confuse people with triangles that only include some factors?
Simply explain:
In order to maintain the same image lightness, if you increase one factor by a stop, you need to decrease another factor by a stop. The factors are: subject lighting, aperture, shutter, and ISO.
If you want to make the image lighter/darker, increase one factor without a corresponding decrease in another.
In what way does a triangle make that clearer?
Did I say that it would make it clearer?
The next step is to elaborate on how the photographer can choose to fix one or more of these variables, and allow the camera to adjust only the rest.
For instance, it is reasonable to show the beginner how to put the camera in Manual mode with Auto-ISO. This is a great way to teach with a digital camera.
The beginner can then play with aperture and shutter to see how they affect depth of field and, along with subject lighting, how the combination of the two affects image noise.
That's a great way of introducing the concepts that just wasn't possible with film. Which is why many who use a film based workflow don't think to use it.
The beauty of this is that this is a workflow that can be used on professional shoots. Set the wides aperture that yields sufficient depth of field. Use the slowest shutter that doesn't yield unwanted motion blur, and you are guaranteed the highest exposure (and therefore least noise) for the lighting conditions.
Teaching a beginner to use a fixed ISO tends to do them a disservice, unless they intend to be primarily shooting film.
"Fixed ISO" is not so fixed because you can adjust it.
In Aperture priority mode the photographer selects a "fixed" aperture, and the camera selects shutter and/or ISO.
But if you don't like the term "fixed", then substitute "Selected". For example
"Teaching a beginner to Select a specific ISO tends to do them a disservice, unless they intend to be primarily shooting film."
Then I must have been doing it wrong because this is the way I shoot almost all the time. I am pretty good with guessing a good ISO for the scene, and fixing the ISO in Av mode fixes the noise level. If I get an f-number and SS that I do not like, I would adjust the ISO - once only because I already got the data from my camera. I do not mind or care if other people do it differently, but it is definitely not wrong, even for a beginner.
Yes, one can guess at the ISO to use, and get good results. However that does not mean that guessing is better than Auto ISO. When the conditions can vary, Auto-ISO can often get you better results.
Suppose you are shooting indoors with available light. Perhaps you need f/5.6 for enough depth of field, and 1/60 to avoid motion blur. With these settings you get a good result at ISO 800. Based on this, you set the camera to ISO 800, and either shutter priority or aperture priority with the above settings.
Now, suppose you are moving around, and the room is not evenly lit. If you move to an area where there is one stop less light, the camera will either give you a slower shutter and unacceptable motion blur, or a wider aperture and not enough depth of field. If you had chosen a fixed f/5.6, 1/60 and Auto ISO, the camera would have simply chosen ISO 1600. You would have a slightly noisier. but useable image. Personally, I find it easier to address noise is post processing, than too shallow depth of field or too much motion blur.
But what if you move to area with one stop more light? With ISO 800 selected, the camera will either stop down, or use a faster shutter speed. This gives you more depth o field than you need, or more motion stopping than you need. However, of you had chosen a fixed f/5.6, 1/60 and Auto ISO, the camera would have simply chosen ISO 400, and you would have gotten a higher exposure, and less noise.
The bottom line is that selecting a particular ISO locks you into a particular exposure (and the associated noise level). Selecting aperture and shutter with Auto-ISO allows the exposure to vary with conditions, guaranteeing the highest exposure (and therefore lowest noise) for the situation.
Obviously, there are scenarios where you have to compromise on more than one factor, and this requires a little more input from the photographer.
The problem with what you advocate is that it is not so universal. Sometimes the light is so low, that you sacrifice the DOF, and change the idea of the shot to accommodate it. In low light, I would often put a fast prime, and that would make me shoot differently. Same with the shutter speed. When I shoot concerts, for example, I would go to slow speeds like 1/60 or even 1/30 sometimes, wait for the right moment, or take a few shots, hoping that some would be sharp enough. In other words, there is a balance you may want to achieve between noise, DOF, and motion blur, with some compromises in each one of them.
Absolutely, there are times when the photographer needs to have a good understanding of what the various factors do and how they interact. My suggestion is that it is better off to teach a beginner how to shoot in reasonable light, before we teach the techniques for dealing with challenging situations.
One of the reasons it's important to teach correct facts and terminology is that when you reach that point, it's easier to teach how to deal with challenging situations.
A good example of this is that some teach that a low exposure results in more noise, others teach that high ISO settings lead to more noise. While both may work for a beginner, only the former is correct. The issue is that someone who believes that the ISO setting is the cause of noise, might come to the conclusion that they can shoot raw, leave the ISO at 100, and then lighten the image in post processing. After all, at ISO 100 there shouldn't be any noise?
This is getting out of the Auto or semi-Auto settings.
Yes. I am not suggesting that one needs to discuss this with a beginner. I am suggesting that it is important to teach the beginner the correct explanation so that if they reach a point where they want to address a challenging situation, they have a good foundation and don't reach incorrect conclusions.
Also, in good light, I may decide that 1/125, f/8 is all I need and let the camera decide the ISO. The camera may very well compute ISO 25 then...
But of course, full auto (including Auto-ISO) is a great way to get a beginner started. One only needs to move to aperture or shutter priority (with Auto-ISO) once the beginner wants to start controlling depth of field or motion blur.
I did not mean exactly that. Fixed ISO and Av or TV are auto modes that are not "fully auto" like the green square.
The green square is only fully auto when you have selected Auto ISO. With s specific ISO selected it's still called "Full Auto" because that's what it was called on a film camera. Film cameras did not offer Auto-ISO.
On my camera, the green square is a phone-like setting. Everything is auto. I never tried it though.
It seems this varies with camera brand.
