goactive
When I first got in my a6700 I tested it with off camera flash just at home for a few test shots and it worked no problem.
Yesterday I took it out on a job and used off camera flash for the first time in real use and ran into a strange problem that now today at home I can reproduce over and over.
When shooting everything will be working great the flash fires and takes a photo then all of a sudden I push the shutter button and nothing happens and the camera is locked but then 4 to 15 seconds later the flash fires at random and the camera is back working.
Go to take another shot and the camera dose this again the flash files maybe at 5 second time or some time at 12 second later each time the camera is locked up till the flash is fired.
Some times it may do this 3 or 4 times in a row and then go back to working as it should for 5 to 6 more shots and then dose it again all messed up.
I did this on the job so I had to pull out my Nikon Z6 I also had with me to finish the job.
Now testing it today I can repeat this problem over and over.
I can be shooting maybe 10 to 15 shots all working perfect and then all of a sudden the camera locks up and the flash fires many seconds later and then the camera is back unlocked but it will may times do this over and over in a row 4 or 5 times doing this lock up and flash delay and then just go back to working right intermitting.
I am using a off camera Godox ad200 flash and shooting all in manual.
It works till the camera messes up and then it dont but then will g back to working till it messes up again.
Its like the camera is going into a self timer random mode at times so it is not taking the photo till it wants to at any given time and it is different each time ranging from 4 to 15 seconds.
Is there any setting I should be looking at to check before I have to send this back for a replacement and hope the replacement dose not have this same problem.
I do want a working replacement not to just send it back.
