M
More Keepers
Guest
I'm not convinced to sell my D810 and get more MFT gear. At this point I'll keep a foot in each camp, but stay with the better lenses for the FF. Weight just isn't an issue for me at this point. Everyone has different needs and priorities so a blanket statement on which is better is ridiculous.If you are using the same DOF with FF and mFT at base ISO, then FF will have the advantage as it has more pixels and gathers more light.I've always been in favor of larger sensors (though only owned APS-C cameras). What I've noticed is that with pretty much every lens I stop down. The wide angles get set to f8 or f11 for landscapes or environmental portraits. The f2.8 and f1.8 primes get stopped down to f4 or f5.6 for sharpness and for enough depth of field. I'd do the same on a full frame body.
Which begs the question-- Is a full frame camera worth it over a little MFT, considering the MFT lenses from Olympus and Panasonic seem to be manufactured more precisely and are therefore sharper than all but the most expensive DSLR lenses? Whereas on a FF body you can shoot portraits with a 60mm lens at f5.6, on the MFT you might get the same quality image at 30mm and f2.8 (equivalent to 60mm f5.6).
Obviously with FF you still have the flexibility of far superior light gathering with full frame lens+sensor if you shoot wide open. But for many people, the vast majority of photography is done at smaller apertures.
What do you think?
If I had a full frame and a MFT camera I'd do comparisons myself.
If you are using the same DOF and exposure time with FF and mFT, then both systems will collect the same amount of light, and the noise advantage of FF will vanish, and, in fact, be at a slight disadvantage due to the greater electronic noise of more pixels.
However, FF will still record more detail (unless using good lenses on mFT and mediocre lenses on FF, you're stopped down way into diffraction softening territory, there's motion blur, or other resolution robbing issues), so the use of noise filtering may well still result in FF retaining more detail for a given level of noise in many situations.
Regardless of which comes out ahead, the differences will likely not be large enough to "justify" one system over the other. Thus, the advantage falls to mFT based on size, weight, and price.
