ejmartin
Thank you for a concise, informative and polite response.Because in dcraw document mode (-D -j) we have several steps ofIn what way is the data "more RAW" that dcraw document mode?
postprocessing:
- Fuji S5 data is stretched two times in long side direction to
2150x1440 pixels
each pixel become two-component (not one as in original bayer). S2
data is
not stretched because real sensor has right aspect ratio (2944x2144)
demosaic stage)
- Image extracted 45-degree rotated (for easy interpolation on
stretched), then one half of pixel values is simpy dropped in
- Black level subtracted
- Either in document mode (-D) values are scaled to fit full range
- If file was stretched on the first step (S3 and S5 files are
'document mode'
with bi-liniear upsize to
- If no -j ( NO fuji rotate) option is given, image is rotated back
3000x2000 pix
So, result is not RAW , just postprocessed less (than full color
- For 8-bit output gamma correction is performed
processing): resized, scaled, one half of values dropped...
emil
http://theory.uchicago.edu/~ejm/pix/20d/
