mplkn
Forum Enthusiast
Ok I'll dig back through the thread: were the two 45s the same?
I haven't tested both of them.Ok I'll dig back through the thread: were the two 45s the same?
Not bad at all indeed. Significantly better than the 110mm.
Indeed. You may have noticed that now that I'm doing this for every lens, I'm using Matlab for the graphs instead of Excel. Much less labor intensive.Not bad at all indeed. Significantly better than the 110mm.
Yeah, once you get the scripts set up, way easier. I'll be curious to see how the other lenses turn out. My guess is that most of the others should be pretty good with the possible exceptions of the 120 where I saw some of the same jitter behavior as with the 110.Indeed. You may have noticed that now that I'm doing this for every lens, I'm using Matlab for the graphs instead of Excel. Much less labor intensive.
blog.kasson.com
Can you see common traits between 'good' and 'less good' lenses with regards to focus shift/focus slip?
blog.kasson.com
Just to say, it's good to see that most (?) lenses may not have the issue.Too much randomness for me to tell.Can you see common traits between 'good' and 'less good' lenses with regards to focus shift/focus slip?
blog.kasson.com
Well that is frustrating. At least with the 110mm you know you can't trust the focus shift data due to systematic error. This is so close.
blog.kasson.com
Wow, I wasn't expecting that given that the other lenses which tested poorly were larger aperture lenses. Bummer.
blog.kasson.com
Unusual, the first three sets it never hit peak 'focus', is there something else going on there?
I dunno. Maybe vibration for the first series. I use a 10-second self timer when I'm doing the f-stop series, but not for these focus bracketing series. As to the other ones, maybe there's some residual vibration from the camera's racking focus back to what it thinks is the original position.Unusual, the first three sets it never hit peak 'focus', is there something else going on there?
blog.kasson.com
I would think that there is a focusing motor and a position sensor. There may also be some mechanical play between focusing motor and focusing group involved.I've been sitting here watching this thread thinking about how the system works and realizing I've never read a thorough description.
There's firmware in the lens, living between the contacts and the focusing motor, taking instructions from the brain and relaying positional information back to the brain (in the camera body), does that sound right?
So, a little mechanical slop in the physical focus mechanism of the individual lens example could result in a difference between the lens's reported position and it's actual position, right?
So the brain might be happy, because the lens is reporting all's well, while in actuality its actual physical focus position would be something else, varying, falling somewhere inside the range of error allowed by the physical slop.
I'm totally making this up. I don't know in detail how the tasks are divided between lens and body. I'm going with assumptions based on some guesses as to how the control system works.
If there's any truth to these guesses, however, it might mean that some examples of a given lens might be better than others. I guess I don't think this is a camera body issue; my guess is the body and brain are doing the best they can based on the information they're getting from the lens.
Thoughts?
It's a control system. Part of the system is in the camera, and part is in the lens. They both are necessary to make focus bracketing work. Usually, in voice coil actuator systems, if absolute positioning is necessary, there is an absolute or relative position sensor. If relative, the control system needs to return the mechanism to a known position (such as against one of the travel stops), then compute absolute position from there. Position sensors are subject to lack of precision, absolute accuracy errors, relative accuracy errors, hysteresis, backlash, etc. So are VCA control systems. If the lens is focused by as stepper motor, that has its own set of precision and accuracy issues. The system computing the stimulus to the motor is also subject to precision constraints, and in addition the time to complete the computations may depend on what else is going on in the camera.I've been sitting here watching this thread thinking about how the system works and realizing I've never read a thorough description.
Thoughts?
