If you want more than 15 images in the stack, you have to use the "Focus" option under the "Bracketing" menu (which is itself right above the "Focus Stacking" menu), where you can set the image count to a much higher value. Of course, you will then have to do the stacking yourself.Has anyone had luck with this function. Only 15 images. just can't get much depth of field. My OM-1 was excellent.
Any info from Panasonic?
Jack
Jack
I am mainly interested in camera bracketing and stacking via Helicon or Zerene. For outdoors I think a high bracketing speed is increasing a lot the success rate handheld or even on tripod to minimized movement. So how fast is the S1RII in camera bracketing mode (no flash)Using the Lumix 100mm f2.8 Macro lens
Stacking photos can be taken in Raw but the output is in Jpg. As you noted 15 shots are not enough for most subjects. Bracketing works fine I have shot up to 100 plus images with good results and few artifacts in Zerene and Photoshop.
Hope this helps
Jack
Somebody else with deeper tech knowledge will probably speak up, but I suspect it's down to sensor readout time.Thanks for that info, I hoped that would be faster. The OM1 took only 4 to 5 sec as far as I remember. 20 sec is great for studio conditions but for outdoor only on tripod and some not moving objects, the same problem as with most FF cameras.
