paulbod3
Leading Member
Wonderful, but very few lenses are to be considered flat field, some macros and the ones for copying ; in most cases the focus is to be mantained on a nearly spherical surface that mimics the front element curvature.
Is that an accurate rule of thumb? I have a 35mm lens (for 35mm FF) that has a CONCAVE front element. What is that supposed to tell me?in most cases the focus is
to be maintained on a nearly spherical surface that mimics the front
element curvature.
element curvature.
So have I, along with two 35mm lenses with small, "bulbous" convex front elements and one with a quite large, almost flat front element. None of them appear to have radically different flatness of field.Is that an accurate rule of thumb? I have a 35mm lens (for 35mm
tell me?
Quite.Regardless, any of these "calculations" that don't take the
individual lens into consideration seem a little dodgy to me.
--Not very long ago I finally realized why I need more than 3 focus
points, or at least 3 points more separated than today on Olympus
dSLRs.
The focal plane is literally a PLANE, not a sphere! When you focus
at e.g. 3 meters you have NOT focused on everything that is 3
meters away from the camera. You have put a plane in focus, a plane
that has its closest point to the camera at the intersection with
the cameras optical axis. All other points in the focal plane are
further away from the camera.
When you recompose after focusing, the focal plane will turn and
end up behind the subject that focus was locked on.
An example: If you focus on the eyes of a model 3 meters away and
recompose by tilting the camera down by 0.5 meter (on the subject),
focus will end upp 4.1 cm behind the eyes. This is a lot if you
work with short depths of focus.
The solution is of course to use an auto focus point that lets you
focus and compose at the same time. That is why I really hope
Olympus will deliver more than 3 auto focus points in the E-1
successor.
Andreas
