I went out today to do some sports stuff with my two Godox AD600 ProII with an XProII trigger and had a a very difficult and situation arise where as I tried to dial in the flash power for the first shot I just couldn't get the lighting to illuminate the subject well. I had one of the lights about 8 feet up with an umbrella angled around 45 degrees and about 6 feet away from ones of the girls volunteering for me to take a few tests to dial in the light.
The flash was going off, but most shots looked like they had no lighting on them. I think I had started at 1/8 and so I pushed it up and up all the way to 1/1 and still wasn't getting what looked like the light was illuminating her. This didn't make sense to me for my 600w unit. I had her move closer to around 3 feet away and suddenly I was getting shots like this: very bright on her arm and nothing anywhere else. I moved her around and tried different angles but kept getting the same. I took off the umbrella, then took off the "barrel" on the flash so it was just a bare bulb - same thing. I was relatively embarrassed at this point and trying to find things to say to help reassure the people waiting that I actually do know what I am doing!
Eventually I dialed in some shutter speed that was giving me what looked like mostly even exposures and started doing shots until after around 10 people the battery on the trigger died. After replacing it I kept going but had mentally moved on from the earlier problems so I didn't think of it. I just happened to be shooting a group at this point so I had to adjust the lighting anyways and it was working great. After this I gradually realized that all of my other shots were working much better now.
On the way home I started thinking trying again to figure the whole thing out and it occurred to me about the battery having died and I started to realize or at least suspect: was the low battery on the trigger causing the flash timing to be wrong/slower so that I was only illuminating the trailing edge of the sensor readout? Is that a possible symptom of a low trigger battery like this? For me, it would explain why I was getting nothing when the person was a bit further away and then, after I pushed it all the way to 1/1 it wound up well over-exposed for part of the frame.
