Giving SSDs to the kids is a great idea.
Is SSD Good for Long Term Storage?
SSDs are reliable when inserting into the machines, it is regularly powered on and is not left unpowered for a long time. So, for SSD long term storage out of the computer, it is not recommended. If you want to take an SSD as the long-term storage device on the shelf, you should store it in proper temp, and power it on regularly for the firmware to do house-keeping work."
HDDs are reliable at storing data for long periods of time without being supplied power and are a preferred method of storage for backups.
The Best External Hard Drives - by Scott Gilbertson on Wired.
Creating images to tell a story... just for you!
Ashley.
With SSDs, electrical charges leak when not powered on for long time, which can lead to data corruption.
With HDDs, the data stored by using magnetic charges, which can decay, and demagnetize at bit level, making data corrupt.
HDDs and SSDs also suffers from
URE (Uncorrectable Read Errors) though it happens rarely.
Prevention: Power on the HDD / SSD at least once a year, leaving it on for a day maybe. SSDs will do the garbage collection / trim if needed, HDDs will do SMART checks and keep everything in check.
Buy quality HDD / SSD: Do not buy cheap QLC SSDs, they do not last long. Best solution is to buy enterprise grade SSDs, they come in 1.92 / 3.84 / 7.68TB sizes, only slightly more expensive than standard SSDs. They have high quality cells, have a higher tolerance to URE, and have exceptional write endurances, and likely to outlast 2-3 times the life of any consumer SSDs. Intel, Micron, Samsung they make good enterprise drives.
Same goes for HDDs. Buy enterprise grade hard drives, they are very reliable and lasts a long time. They have quality components, high workload ratings (for example: 55TB for a normal desktop drive, 180TB for a NAS drive, 550TB for a enterprise drive), high MTBF.
