John down under
Hi Paul,Trying again,
If this works thanks Barry.....
Let's see now......
Ooops! sorry its so big, the site said if it was too big it would
shrink it.
Good to see you here on the MTF, with a little help from some friends along the way! ;o)
It is also good to see you were able to follow my guide to using Photobucket. AFAIK, Photobucket only resizes your pic if the file size is over 250kB. I don't know whether it changes the dimensions in pixels, or just compresses your original to less than 250kB as I have not looked into it. However, it is always best to consciously choose the dimensions yourself. In PhotoShop Elements 2, for example, choose Resize from the Image menu and choose the dimensions you want in pixels. As you will have seen, the dpreview message box is 480 pixels wide, so anything wider than that will have to expand to be fully seen. Depending on the pic, 480 may be wide enough, and it would not be common to need to post a pic in a thread at more than 800 wide. I usually choose 480, 600 or 640 wide (640 x 480 is still a 4:3 ratio).
