Howdy
Leading Member
Thanks for the explanation, Shay. The argument is based upon green being the primary (sole?) basis for determining luminance in most interpolation algorithms. So, bobbo had TurboTed are referring to luminance as 'detail,' and from this 'fact' proposing that since a 5mp mosaic gets 2.5mp of luminance data, it is really only a 2.5 mp sensor, and thus can be treated as a 3mp sensor without losing detail.
Still don't agree with the argument, but at least I have an understanding of the basis on which the argument is being made. As I understand interpolation algorithms, the argument would be 'truer' for earlier, less developed algorithms, as they apply a straightforward 'interpretation' of the luminance data. It becomes less true for the more developed, more complex algorithms, which (as I think I understand, though I may be wrong) massage the luminance data in the context of color data and vice versa.
And if it helps, I do recognize that a 5mega-sensel (ms) mosaiced sensor (such as the 707) will have less resolution than a 5ms foveon-type sensor. Whether the 3mp foveon will have better resolution than a 5ms or 6ms mosaiced sensor remains to be seen, but I understand that the math would suggest it will be close.
But, back to the original proposition. That luminance is derived from the 2.5million green channel/sensors, and is then interpolated into a 5mp image does not lead to the conclusion that reducing the raw data to 3mp size before interpolation (which, I believe is the suggested procedure being followed by Sony in the 707, although I have no knowledge) will result in a 3mp image with as much 'detail' or luminance information as a 5mp image.
Howdy
Howdy
