dnjake
The only thing the firmware upgrade means is that the problems fixed were the software problems that Canon knew about at the time and had a fix for.Also, Canon has released a firmware upgrade which did not address
any AF issues. This means there is no systematic AF issue. There
exists an official statement released by Canon Germany explaining
why one might (seemingly) encounter "AF problems".
I think that it is pretty clear from Canon's own statements that there is a systematic autofocus issue that affects the 10d, d60, and d30. Basically they used full frame technology for a smaller frame camera. In both cases, the autofocus system guarantees that the subject will be in focus at the same minimum resolution of around 30 lines per mm. But the small frame camera images need more magnification. So the subject in the image you see from the small frame camera may appear to be less in focus.I invite you to present material which shows a different story or
at least links to sources with a minimum degree of credibility.
Why it has become a bigger problem for the 10d than it was in the past and why it affects certain users much more than others is less clear. It does seem clear that for most cameras, the autofocus system is still good enough to be satisfactory to most users. It also seems clear that the controversy surrounding the 10d has caused users to be quicker to find problems with the system.
I am pretty happy with my 10d. I was not too worried about the autofocus system to begin with since most of the pictures I like to are focused on infinity. In the cases, that require more precise focus, my camera seems to be working well.
But I do think that a significant problem in Canon's quality control has come to light and that it will take a while to see how they are able to deal with it.
David Jacobson
