I really wanted to get to the bottom of this. Now, tests with manual lenses, so no distortion correction.
Here are comparison shots with Samyang 7.5mm fisheye, E-M1 and E-PL5. Both are carefully focused at longest visible tree, close to infinity. On E-M1 I had to move focus ring a bit closer to infinity stop than on E-PL5, by almost half a millimiter or so. So, there is flange distance difference between cameras.
E-M1
E-PL5
I drew 1 pixel wide pink vertical lines on photos - these show where I measured distance, you can see it when you download full size image.
Distance: E-M1: 4539-1231=3308, E-PL5: 4475-1063=3412
Difference - 3.0%, E-M1 can capture image wider by 3%.
Since flange distance is different, lens focusing element position is not the same - optical configuration differs. So, we can't realy be sure if optics results different image sizes or sensor sizes are different.
Here are tests when lens opical configuration is the same. I used m42 Helios 44-2 58mm F2 lens. m42 mount is unique because it's a screw-mount (well, C-mount is too, maybe some others, but I had a good m42 lens with adapter).
As opposed to bayonet mount it allows to adjust focus by unscrewing the lens from adapter.
By screwing the lens I compensated for flange distance differences. Both shots are focused well and lens focus element stayed at the same position for both cameras (at 10 meter mark on the lens).
E-M1
E-PL5
The distance to fence where I focused is 18 meters, not infinity, but, I think it's far enough to estimate magnification.
Because the lens is not firmly screwed to adapter it's tilted a bit, you can see that the right side is softer than the left one, focus plane is tilted. This doen't happen when the lens is firmly in place. But, since the picture looks similar for both cameras I hope it's a fair test.
E-M1: 3719-280=3439, E-PL5: 3802-263=3539
Image on E-PL5 sensor is larger, so E-M1 sensor must be larger. Difference - 2.8%.
No matter how I measure it, the difference is always almost the same.
Conclusions:
- EM1 sensor does seem to be larger than E-PL5 (E-M5) sensor by about 2.7-2.8% linearly, but I'm open to critique of my test. I'm skeptical myself, the difference seems to be large enough that somebody else should have noticed it.
- On the other hand, the difference may be small enough so most will not care. I probably will not care either, unless I'm stressed to capture something really big and I need to squeeze everything from UWA lens.
- There are flange distance differences between cameras. They may affect results too, and amplify sensor size differences sometimes. At close (2-3 feet) focus distance the difference in magnification may exceed 5% as I showed in 17mm F1.8 test. E-M1 will see much farther to the edges of the frame than E-PL5, this should explain its lower scores in DXO mark tests as edge resolution will be lower with the same lens. But this may vary between camera samples so people should test it by themselves.
- AA filter strength (and sharpness) is probably the same on all Olympus cameras since E-M5 until now.
