Hello. I am unable to find this info anywhere. Question about h.265 N-log vs standard and dynamic range. According to Nikon, Log delivers 12 stops dr (this may only be n-raw?).
However, according to Nikon DR drops when using iso lower than 800. The 8/9 series have low settings that are 200/400/640.
What I’m curious about is in the lower settings, am I getting less or equal DR to standard h.65? Curious if anyone has seen info on this. Even with a decrease the benefits of log are still beneficial for color grading and mixing standard and log footage is far from ideal.
It's odd that Nikon (to my knowledge) doesn't provide this information in any meaningful manner.
It's more a matter of pure interest and nerding out.
You are bringing up a few issues here and I don't think there is much if any official info on this at all. Horshack has looked at the log v SDR issue but I'm not sure exactly what he concluded in his deep dive. I would need to have another read through a very long thread which I guess you are familiar with.
Anyway that was before my time on here and I did some testing myself before I came across Horshack's excellent work. I would have to dig out the tests and remind myself of exactly what I found but I recall some conclusions which might shed some light on your question.
In relation to the log v SDR comparisons, I found that there was little difference in dynamic range when working in raw (NRAW or ProRes Raw) once corrected for the ISO differences. In other words, there is no significant difference between Log and SDR in terms of highlight or shadow detail or in terms of noise. I think the SDR raws can develop a greenish colour cast in the shadows if pulled too far but otherwise there is little to choose. I chose to keep working in Log in any case.
However, there is a significant difference when working in non-raw formats (H.265 and ProRes) in terms of shadow detail. In SDR the shadow detail can go to complete mush whereas somewhat better deep shadow detail can be recovered with Log. I came to the conclusion that Log is the only way to go if working in either ProRes or H.265.
In relation to the Lo ISOs, it is very easy to check what is happening if you look at a waveform in camera or in post. If the highlights are clipping at ISO 800 as indicated by a flat top in the waveform, going to lower ISO has no effect on highlight recovery so there is no gain in dynamic range. I quickly came to the conclusion that these so-called false ISOs are of little use to the way I shoot video (essentially ETTR with the waveform) as there no benefit in terms of highlight recovery. Others may find these false ISOs benefical. I don't.
Incidentally the Z6III has the same Lo ISOs and I've just checked that they do exactly the same as the Z8 and Z9.
