Digital Nigel
No, the advice was on how to see the effects of your edits, not to do no edits.It helps a lot! So, what edits? The idea is to use only Deep Prime and eventually perspective corrections. The rest you can do on the Tiff file.That was doesn’t help you see the effects of the edits.If you want to really see you can always export a 16. Bit tiff with only perspective and deep xd applied to th RAW.An excellent piece of advice. I have seen YouTube channels where the guy always uses the fit to screen image to assess the image and unfortunately, with PhotoLab this is not a good idea. You need to use software correctly and each piece of software has its own quirks.As I’m sure you know, but sometimes need a reminder, what you see on the edit screen doesn’t reflect all your edits. So, often the image is going to look much better on export than it does on screen. The loupe tool is worth using, and it’s nice that it stays active as you do edits.
Loope Tool was a much needed addition to PL.
Ian
