Pennypincher
Leading Member
Mines a 1999 model that came with nothing more than a 52x cdrm.Im interpreting your post as saying i could plug my internal hardrive into one of the 2 or 3 extra internal IDE receptacles inside my computer box and my existing hardrive would operate it recognizing it as a slave,so long as i plugged it into the IDE receptacle right next to the one the existing hardrive is attached to (both must connect to the same cord).
No other work or programing is required because plugging it into the slave receptacle sets it as a slave.
Well if thats wrong i guess id just be out $14.
This leads me to ask if i couldnt just order another bigger desktop internal hardrive (because im aware of how much cheaper they are than notebook hardrives) and connect it exactly the same way? I could try out the notebook first to see if im doing it right then move up from there?
Hope im not becoming a major pest with this.
thanx
Dan
thanx
Dan
Hope this helps..
Mike
http://www.cablesnmor.com/hard-drive-converter.html
Here is a write I did on the IB a few months back...
http://208.231.0.96/bedpan/IB/
Good luck..
Mike
Mike
As for what to do with the broken IB... I would suggest trying to
find a friend that has some electronics skills. There is a good
change the CF connector could be soldered back onto the PCB and get
it up and running again. Been awhile since I had my IB open, so I
don't recall if this connector is Surfance mount, or Pins... If it
is surface mount it might be a bit tougher (but not impossible) to
fix..
I will pay the shipping if you want to send it to me ;-)
Mike
Well after using my image bank just a few times in the safety and
security of my office area i apparently broke it.I sat it on a file
rack next to my desk which stood no higher than my desk (2 1/2 feet
) so i wouldnt have to step over the cord but immediatly caught the
cord with my foot and it fell the short distance into a bunch of
soft garbage.Looks like it landed on the CF card and memory stick
because the little tray i slide the CF card into looks detached
from the circuit board on one side and the cf card seems to slide
in deeper on one side than the other.The poer wont turn onIm sure
even fine china would have withstood the little tumble it
took.Unfortunatly since i have no power i cant tell if my files are
ok in the hardrive.My 90 day warranty expired 4 months ago and i
guess this wouldnt be covered.
Any tips or advice would be apreciated...seems like i should get
power at least.
I just ordered another Image Bank with power Bank but im not going
to be willing to erase my hardrive to formate it.
Disapointed
PS ,the top panel of my ms to CF card adapter popped apart a few
days ago when i was slidding in a memory stick.I know you must
think i must be some rough unco-ordinated 300lb turkey ...not so
...this stuff is fragile,very fragile.
Im sitting here with 5 ms sticks i want to see wondering if my
hardrive is erased and how much its going to cost to repair or
replace this junk
Dan
