Actually better.Mark Scott Abeln wrote:
Many high-quality, sharp pixels downsized should be equivalent to fewer, lower quality pixels when downsized --- right?
Higher resolution image when downsampled properly to a lower resolution image should result in a higher quality than an image acquired directly at the lower resolution.
There is a very strong connection here, though not directly by Shannon.So how does this fit into sampling theory according to Nyquist and Shannon?
Downsampling using linear methods is often not properly implemented. That is why one has to use heuristics-based sharpening for pleasing affect. However, sampling theory does provide some notions for determining "optimal sharpening" filters. For e.g., displayed below is the "optimal" sharpening filter for a simple 2x2 linear interpolation downsampling.
Yes, if you compare the resulting lower resolution target image to an image acquired directly at the target resolution.Does the fact that we are initially capturing highly-defined pixels mean we still get better pixels after downsizing?
Basically, with better methods you can have a sharper cut-off filter than simple averaging filter.So if we eliminate ten pixels in a row by downsizing, we aren't merely doing an average of those ten pixels, but instead are doing something closer to dropping the excess pixels? The latter seems to me to preserve more original pixel contrast.
My impression is that Photoshop uses filters designed for interpolation (upsampling) for downsampling, without proper pre-fitering. See the above image on one way they could have derived the "optimal sharpening" filters.Also, I'm curious to see what algorithms folks use for downsizing. I use Photoshop and my choices are limited. I find Bicubic Sharper to look too artificially sharp, while Bicubic is a bit soft and needs additional sharpening to correct. Lately I've been using Bilinear, which tends to look better, at least for landscape pictures. For my best work, I'd be willing to use other algorithms even if it means I have to use additional software.
Joofa
Dj Joofa
