tallahassegreys
Active member
Here's the question: Does it make sense to learn DOF charts as a function of FOV, as opposed to focal length and distance to subject?
Here's the background of my question: I am finally starting to take a close look at DOF charts after realizing that many of my shots may be coming out soft as a result of shooting at wide apertures....which is a bit disappointing since the only reason I bought the 35mm 1.8 and 17-55 2.8 is precisely to shoot wide open!! But DOFMaster is showing me how incredibly shallow the DOF field can be in may circumstances. One option to increase DOF is to back up, but then I need to zoom in to have the same FOV.
I have checked out the Dimensional Field of View Calculator on http://www.tawbaware.com/maxlyons/calc.htm and confirmed that FOV remains constant if you vary focal length (FL) and distance to subject (DTS) by the same factor. So basically any of a number of combinations of FL and DTS can be utilized to achieve the same FOV. So it therefore seems more practical to learn or "memorize" the DOF charts as a function of 1 variable, namely FOV, as opposed to two variables, FL and DTS.
Does this make sense? And if so is there a DOF chart that indexes DOF with FOV?
