do you use a filter on your DP2 Quattro, and which one?
miro3
US
Do you use a filter on your DP2 Quattro, and which one, i.e.,
clear or UV, and which make and model?
I never use UV filters. Only filter I have used is a Sigma circular polarizer.
I use a clear for generally just added protection and a circular polariser for bright/contrasty days/scenes. Both B+W brands.
I have not used one yet but I can see that with the DP2Q's shutter speed limitations of 1/1250 wide open, an ND filter would be useful to have around on occasion.
Generally I agree that filters degrade the image. Avoid them whenever possible.
Reasons for using a filter - lens protection. Depending on where and how you take images - a filter might be called for. After all it is better to have blowing dirt/sand to damage the coating on a filter than the coating on a lens or in the case of a fixed lens camera - the camera.
Reasons for not using a filter - flare is probably the biggest one. Extra glass can result in flare.
If you do use a filter make it the best optical quality. B+W makes good filters. Stay away from the cheap ones.
I always have a filter on my camera. I've had filters save my bacon more than once and if you use a camera for long enough you will have a filter save you bacon. However, unless the conditions are such that I need a filter on, I screw it off when actually taking a shot.
I use a Sigma UV filter on mine, just like I did with my previous DP2M. The front lens element is quite exposed on the DP2, so I prefer to protect it a bit.
Adding the UV filter increases the risk of flare (the only real life image degradation), so you want to use a hood. Ironically, adding the hood reduces the need of the filter in the first place ;-)
With my DP3M I used neither a filter nor a hood since the front element was recessed at typical focus distances.
