technicsplayer.
tripod detection has been around for a while. With non dslrs you should just switch off IS for tripod work.
Only if you are 100% sure that your tripod is rock-solid, and the camera is not extended above it. And that there is no nearby foot or vehicle traffic. And that there are no air-currents that could slightly move the camera. And that you are not standing on a wooden surface that will shift in minuscule amounts as you shift your weight. (I have to be cautious of this when using my analytic balance, even though it is setting upon a large marble slab to help stabilize it. Just slightly moving my weight from one foot to another will make the balance's weight display change by .1 micrograms or more.)A big thank you to all who have participated here.
Some interesting comments.
My conclusions are:
It's probably best to switch off IS when using a tripod.
I get a whiff of paranoia here. I take pictures in the real world without worrying about measuring atomic weights timed by an atomic clock.Only if you are 100% sure that your tripod is rock-solid, and the
Good for you Jenkins, you leave yours switched on, but don't forget that IS is designed to counteract human induced shake while holding the camera. Countering the effect of passing trucks, gales blowing and the odd earthquake and what-have-you while the camra is not hand-held were not part of the design brief (entirely different frequencies).From my tests I found that leaving IS on will always be a benefit
to ANY unknowns.
Jenkins, your arrogance is breathtaking ! Do you really think everbody else (S3 IS users included) is just noise and should be ignored except for you !!!(Read my post above on how little IS imparts its own movement in
the S3 IS once it's on a tripod, you seemed to have missed it
amongst all the noise. The rest of the noise in this thread is from
people talking about other cameras and lenses who just feel the
need to put in their unrelated 2 cents.)
SteveH, your ignorance is breathtaking ! Do you really think that everyone talking about every other lens and camera EXCEPT the S3 IS that the OP asked about has anything to do with the S3's image stabilization? For those other lenses and cameras, their point of view is valid. For the S3 IS their point of view is useless noise.Jenkins, your arrogance is breathtaking ! Do you really think everbody
for you !!!
Jenkins, I really cannot agree with your blinkered/blindered view point.Do you really think that
Duh, I wonder which camera this question is refering to.Do you switch IS off when using tripod or other support ?
SteveH - 4 days ago
In the instructions for a Canon IS lens for use with SLRs is says to
switch off IS when using a tripod or other support.
I don't see any mention of this in the S3 IS* manual
Do you switch off or just leave it on ?
I wouldn't rely on a visual inspection of the LCD to judge drift if I were you. It has far to low resolution to tell you if the final image is going to be truly sharp.Put the IS settings to continuous and tele-converter
options. Then watch how that image doesn't drift for a whole
minute.
It must have escaped your attention that the main purpose of these forums is to share information, experience and pictures. Asking what others do can hardly be construed as relying on the work and opinions others. Get informed then make a judgement.Instead of relying on the work and "opinions" of others, why don't
you do the work yourself just as I did and remove all doubt? (just
as I did)
! ! ! ! you must weigh a whole lot more than I doOr jump once to emulate a passing car on solid ground.
If asking for peoples opinions is so silly then why do you demean yourself by getting involved?But no, you'd rather sit there and start some silly cyber-cry for attention
"We" didn't ask you to do any work, you took it upon yourself to do the work as obviously you didn't have an opinion to give as it must have never occured to you that there may be some situations where it is better to switch off ISWork that I wasted doing for the likes of you.
Bravo, who's a clever chap now?But I'm glad I did those tests for me because now I know more than you do.
Now you are simultaneously clutching at straws and jumping to conclusions.Duh, I wonder which camera this question is refering to.I don't see any mention of this in the S3 IS* manual
Are you unable to communicate without resorting to petty school yard insultsNow go away little boy and do your own homework.
to switch off IS when using a tripod or other support.
I don't see any mention of this in the S3 IS manual
