Leonard Shepherd
This is what I anticipate but do not own a D5/500 yet.It's unavoidable that the detection lines are a little shorter, as the AF point array has no space between points, and the number of points has increased since the D4.What would be worth knowing is, have Nikon changed the length of the AF detection lines used in single point AF with the D5/5000? This is easy to check out.
I am speculating that the increased number of AF points in the D5/500, including none selectable, enable shorter single detection lines. If this turns out to be right then several AF test targets may need to be used at a lesser focal length magnification factor for best results compared to recent 51 point AF bodies.
It depends. It maybe that micro electronics has advanced sufficiently for Nikon to pack more individual AF detection points on a shorter detection line.In order to present the D5 AF points with the same detail seen by D4 AF points, the D5 must be moved further away from the target, i.e., at a greater focal length multiplication, not lesser.
I do not own a D5/500 yet but it may be relatively easy to "discover" by selecting an outer line detector and comparing the inner and outer edge results.It is somewhat more complex today. Often more than one AF point is in use and the camera has sole control over AF points in between the user-selectable points. Nikon do not describe the detail of the algorithms which determine how the AF points are used, so it is left to the user community to discover them.The first thing I do when I get a new type of body is to quickly check the length of the single point AF detection lines. If the length is changed a few test shots may be advisable as the new AF system may focus on some things the previous could not, and vice versa.
Leonard Shepherd
You can buy kit. The rest is mainly down to you.
The more you practice, as with a musical instrument, the better you are likely to become.
