Thomas Gardner
The way I read your work flow: each image will have to be attended to individually?Set WB to "as shot" .... or you can play with WB in the conversion
for special effects for things like sunsets.
Yep, depending on the lighting/shooting situation this might be needed ... maybe even custom WB by picking a white point with the pipette ... a point of the thumbnail that comes close to 18% gray seems to work best.The way I read your work flow: each image will have to be attended
to individually?
The flaw I've found with the "pipette" method is, the white you choose will be influenced by the light source, 240, 202, 153 and there by create clipping and a color shift as the pipette raise the contrast of the image. On the other hand, the best black in the image may consist of 9, 9, 9 and then you'll introduce clipping further on the black end.Yep, depending on the lighting/shooting situation this might beThe way I read your work flow: each image will have to be attended
to individually?
seems to work best.
