TacticDesigns
- Messages
- 8,446
- Solutions
- 9
- Reaction score
- 3,729
Sorry.No, we're using the word the same way, but I'm not sure why the question about printing on a piece of paper. I not seeing how it's a problem. It's possible that I'm overlooking something and over simplifying.It actually wasn't a question.I'm lost with that question. At the very edge, the image will be sharp and free from aberration in theory and so in the center - the sensor is just transmitting pulses for a given location. Are you thinking as if you would flatten out the sensor and therefore have gaps in the image that need filling in? I guess I'm assuming the sensor is curved after the photo sites have been placed. Maybe not?+1And spherical aberration and coma etc.Things like chromatic aberration and distortion?You don't need to flatten the data.+1this is the Sony curved sensor discussed here :+1You're thinking of those old panoramic cameras where the film was held on a semi-circular arc and the lens was rotated mechanically. These are very subtly curved sensors which compensate for the field curvature, rather than using optical elements in the lens to correct it. This Wikipedia page gives some examples:I've just read what has been posted on this site about curved sensors.
Haven't really read too much.
But 2 questions.
1. Would curved sensors work well with trying to capture 180 or 360 degree pictures?
https://en.wikipedia.org/wiki/Petzval_field_curvature
J.
Those panoramic cameras are exactly what I was thinking.
With the film, you could only bend (roll) it in one direction (axis).
But, with a curved sensor, it would be like you were rolling the film (sensor) in all directions.
Would that be the case?
Get on curved sensor and you've got ~180 degrees. Have 2 sensors (one on each side of the camera, like the Ricoh Theta) and you've got 360 degrees, but better IQ?
Take care & Happy Shooting!
My Personal Flickr Favs . . .
http://www.flickr.com/photos/tacticdesigns/sets/72157631300869284/
[FL][RP][LS]
Yes. I guess not as wrapped as the film was in the old panoramic cameras.
But if this gives some sort of advantage to IQ with wide angle lenses, then would this be a progression for wide angle cameras, including fisheye or panoramic cameras?
+1Yes - in the panoramic film cameras the film remained as what the mathematicians would call a developable surface, i.e. you could roll it out flat without stretching or creasing it - they would say that the film had zero Gaussian curvature - whereas the surface of these sensors it is really a curved surface; though with the current technology you clearly can't bend it very much.
What is the benefit of being a "developable surface"?
I can see that because the sensor is manufactured into a curve (somewhere along the process) and then it's shape becomes set, it can't be straightened.
But . . . since the sensor records data, it is possible to "flatten" the representation of that data . . . it can be projected digitally onto a flat surface.
Not what's going on I think. In this case, the lens and the sensor will be matched and the resulting image will be flat field. The point is that a lens already struggles to be flat and we do many corrections to compensate for this.So, it may not be physically possible to flatten the sensor into a developable surface, but digitally it is possible? Yes? So, sort of a digital version of developable surface?
+1What I'm saying is that it will be flat and not require any flattening - at least this is my expectation. IE, a lens wants to project an image that isn't flat. But if we meet that with a curved sensor, then the image will be flat.I guess I'm trying to understand what you mean by the result will be a naturally flat image?Now, there will be fewer corrections required because we'll stop trying to make it project a ruler flat image. Instead, we'll let it have a curve that matches the curve of the sensor. The result will be a naturally flat image.
Do you mean that it will be a cleaner image (less aberrations), but the image still needs to go through digital processing / projection in order to be printed as a flat image, like a print?
Ok. I think we are using "flat" at different parts of the workflow.So we would design lenses that are happily not projecting a flat image in such a way that the curvature of the image matches that of the image sensor. So now, where you would have had poor edge performance, we've moved the sensor surface a bit to cure that. (For instance.)
I think you are referring to "flat" when the lens projects the image onto the sensor. In which case, yes . . . a lens designed to project onto a curved sensor could project a cleaner image.
The flat I'm talking about is when you take the image captured from the curved sensor and try to print it on flat piece of paper.
I understand that we are using the word "flat" in different ways.
I agree with everything you say.
My use of the word "flat" is when you take that image that has been captured and you try to print it on a flat piece of paper.That's all.
I was just trying to understand how you were using the word "flat".![]()
My mind keeps jumping all over the place.
Originally I was thinking that this curved sensor would work nicely with a product like the Ricoh Theta. A camera that captures ~180 degree on each side, and stitches it together.
So my original thought was . . . when shooting RAW, you get the RAW image out of the curved sensor.
My first question was, would this be a good file to pull into something like Hugin to use in stitching? Because it would be a cleaner file than a flat sensor? Cleaner in that there is less aberrations? And wouldn't you want to preserve the curved aspect and not edit the file and make it flat before sending it to software like Hugin?
But . . . is that how the file would be saved? Or would it be "flattened"?
Sort of like what this person was asking . . .
Loading…
photo.stackexchange.com
And then I started thinking . . . ok, let's say you shoot RAW and save the picture.
Now you want to post the picture to Facebook, or print it to a piece of paper. Are you going to require a computer to process the picture, or will the camera itself be able to kick out a flat projection to share?
I am assuming the camera will be able to do that, and have built-in wifi to transfer it to your phone.
But then again . . . instead of sharing a flat image, why not upload a 360 degree view of where you are. So, what format would that be?
So, it was more . . . ok, you've got the capture. It's cleaner with less aberrations. But, then . . . now what? Where / how does that file go?
LOL.
[FL][RP][LS]
