This is the myth we are trying to dispell. 200 f2 on crop gives you.....200 f2 with a cropped image. The FOV matches a 320mm. To get the same framing as you would an uncropped image you back up, and THAT changes the DOF.
Unless a photographer is focal length limited, I'm not sure what the sense is in comparing the DOFs between photos between two systems that have different perspectives or different framing.
For example, would a FF shooter
intentionally use a 200 / 2L IS and crop to 320mm, or use a 300 / 2.8L IS, unless the longest lens they had was 200mm?
Furthermore, I'm not sure what sense there is in comparing photos with different dimensions. For example, why would we compare an 8 x 12 inch print on 1.6x with a 13 x 19 inch print on FF?
More directly, DOF is a function of several variables. These variables are:
- subject-camera distance (perspective)
- framing (AOV)
- aperture diameter (focal length divided by f-ratio)
- display dimensions
- viewing distance
- visual acuity
Furthermore, if the sensors have the same efficiency, they will also have the same noise for the same shutter speed (despite the ISO differential).
That is, noise is a function of the following variables:
- scene luminance
- distance from scene (perspective)
- shutter speed
- sensor efficiency (which, for some sensors, actually increases with higher ISOs)
The first four factors determine how much light falls on the sensor, and the last factor determines how much of that light is recorded, and how much additional noise is introduced.
Basically, in terms of how the equipment is actually used, and in terms of the
visual properties of the final photo , it makes the most sense to say that 200mm f/2 on 1.6x is
equivalent to 300mm f/3.2 on FF.
