Hi,
I shoot my photos with D5600 in both NEF and JPG formats and am wondering if I can create the jpg file on the computer using Capture NX-D from the NEF file that would ****match**** the JPG from the camera. Of course I can convert nef to jpg. Problem is matching to that from the camera. These are the questions I have
Can it be done with ncp file?
How to download the ncp file from the camera?
It looks possible but I am not sure how to do it. If I can do this, then I can just shoot in just NEF format and it wont be necessary to shoot in both NEF and JPG format. I will have more space on my memory cards to take more photos and with NEF I will be able to do more processing which I cant do with JPG.
Could you please help me?
Thiru
I don't understand your reference to an "ncp" file. Perhaps you meant to write "nef" and that is a misspelling.
Anyway, I use NX-D to convert my raw nef files and then immediately relocate the result (as a 16-bit tiff) to other software for further processing because I prefer its editing functionality to that of NX-D. (Note: my preferred editing software, that was one of the first when digital photography first became a thing, does not have raw conversion capability just like PhotoShop lacked any raw conversion ability for the first thirteen years of its existence.)
Nef conversion in NX-D software does indeed perfectly match the look of the jpeg in its default settings. Of course these can be changed for a different output. But I have zeroed in on certain camera Picture Control settings that automatically give me a converted output I like for the starting point for further editing. So I do, in fact, use NX-D in default mode to duplicate the jpeg look. But the result has the bit depth of my settings for raw (either 12 or 14 bit) instead of the 8-bit limitation of the identical looking jpeg. That's why I prefer it for further processing even though it starts out looking just like the jpeg.
I also shoot raw+jpeg and was thinking about no longer shooting raw since that is what I process in NX-D. But that changed recently when I discovered a couple corrupted raw files from an old shoot, whereas the high quality jpeg versions of those corrupted files were OK. I have never had a space constraint on my memory cards from shooting raw + jpeg for two reasons.
1. I am not a spray & pray shooter but am very selective about pressing the shutter release. So I don't generate thousands of images from a single photo shoot.
2. I download my images (and save a duplicate backup) immediately after a shoot because I am interested to see and process the results. Then I reformat the card. So I am seldom using more than a small portion of the card's capacity.
In terms of downloading, I am not familiar with any "import and cataloging function" in NX-D. So I just download the pictures into a properly labeled file folder and then specify that particular folder in the place where NX-D allows you to specify a particular folder. NX-D may have DAM capability, but I don't use it if it is there.
