R
rrccad
Guest
https://www.canonnews.com/complete-specifications-for-the-eos-rp-leaked
IMAGE SENSOR
Type
35.9 x 24 mm CMOS
Effective Pixels
Approx. 26.2 Megapixels
Total Pixels
Approx. 27.1 Megapixels
Aspect Ratio
3:2
Low-Pass Filter
Built-in/Fixed
Sensor Cleaning
EOS integrated cleaning system
Colour Filter Type
Primary Colour
IMAGE PROCESSOR
Type
DIGIC 8
LENS
Lens Mount
RF (EF and EF-S lenses can be attached using Mount Adapter EF-EOS R, Control Ring Mount Adapter EF-EOS R, or Drop-In Filter Mount Adapter EF-EOS R. EF-M lenses are not compatible)
Focal Length
Equivalent to 1.0x the focal length of the lens with RF and EF lenses 1.6x with EF-S
FOCUSING
Type
Phase-difference detection system with image sensor (Dual Pixel CMOS AF)
Coverage
88% horizontal and 100% vertical coverage [10]
AF working range
EV -5 to 18 (at 23°C & ISO100)
AF Modes
One Shot
Servo AF
AF Point Selection
Automatic selection: Face+tracking + Eye AF
Manual selection: 1-point AF (AF frame size can be changed)
4779 AF positions available
Spot AF
Manual selection: AF point Expansion 4 points (up, down, left, right)
Manual selection: AF point Expansion surrounding
Manual selection: Zone AF (all AF points divided into 9 focusing zones)
AF Lock
Locked when shutter button is pressed halfway or AF ON is pressed in One Shot AF mode. Using customised button set to AF stop in AI servo
AF Assist Beam
Emitted by built-in LED
Manual Focus
Selected on lens
Focus peaking provided
EXPOSURE CONTROL
Metering modes
Real-time with image sensor, 384-zone metering (24x16)
(1) Evaluative metering (linked to all AF points)
(2) Partial metering (approx. 5.5% of viewfinder at centre)
(3) Spot metering: Centre spot metering (approx. 2.7% viewfinder at centre)
AF point-linked spot metering not provided
(4) centre-weighted average metering
Metering Brightness Range
EV -3 to 20 (at 23°C, ISO100, with evaluative metering)
AE Lock
Auto: AE lock takes effect when focus is achieved
Manual: By AE lock button in P, Av, Fv, Tv and M modes
Exposure Compensation
+/-3 EV in 1/3 or 1/2 stop increments (can be combined with AEB).
AEB
Anti-flicker shooting
Yes. Flicker detected at a frequency of 100 Hz or 120 Hz. Maximum continuous shooting speed may decrease
ISO Sensitivity [8]
Auto 100-40000 (in 1/3-stop or whole stop increments)
ISO can be expanded to L:50, H1: 51200, H2: 102400,
Type
Electronically-controlled focal-plane shutter
Speed
30-1/4000 sec (1/2 or 1/3 stop increments), Bulb (Total shutter speed range. Available range varies by shooting mode)
Shutter Release
Soft touch electromagnetic release
WHITE BALANCE
Type
Auto white balance with the imaging sensor
Settings
AWB (Ambience priority/White priority), Daylight, Shade, Cloudy, Tungsten light, White Fluorescent light, Flash, Custom, Colour Temperature Setting
White balance compensation:
1. Blue/Amber +/-9
2. Magenta/Green +/-9
Custom White Balance
Yes, 1 setting can be registered
WB Bracketing
+/-3 levels in single level increments
Selectable Blue/Amber bias or Magenta/Green bias
VIEWFINDER
Type
0.39-inch OLED colour EVF
Dot count
2.36 Million dots
Coverage (Vertical/Horizontal)
Approx. 100%
Magnification
Approx. 0.70x [1]
Eyepoint
Approx. 22 mm (from eyepiece lens centre)
-4 to +1 m-1 (dioptre)
Viewfinder Information
AF point information, Exposure level indicator, Number of remaining multiple exposures, Exposure compensation, HDR shooting, Highlight tone priority, Multiple-exposure shooting, ISO speed, Possible shots, Multi Shot Noise Reduction, Number of self-timer shooting, Digital Lens Optimizer, Maximum burst, AF method, Battery level, AF operation, Exposure simulation, Drive mode, AEB, Metering mode, FEB, Anti-flicker shooting, Still photo cropping, Shooting mode, Aspect ratio, Scene icons Auto Lighting Optimizer, AE lock Picture Style, Flash-ready, White balance, Flash off White balance correction, FE lock, Image Quality, High-speed sync, Bluetooth function, Shutter speed, Wi-Fi function, Multi-function lock warning, Histogram, Aperture Electronic level, Lens information
Depth of field preview
Yes, via customised button
Eyepiece shutter
N/A
LCD MONITOR
Type
7.5 cm (3.0") Clear View LCD II, approx. 1.04 Million dots
Coverage
Approx. 100%
Viewing Angle (horizontally/vertically)
Approx. 170° vertically and horizontally
Brightness / Colour Adjustment
Manual: Adjustable to one of seven levels
IMAGE SENSOR
Type
35.9 x 24 mm CMOS
Effective Pixels
Total Pixels
Aspect Ratio
3:2
Low-Pass Filter
Built-in/Fixed
Sensor Cleaning
Colour Filter Type
Primary Colour
IMAGE PROCESSOR
Type
DIGIC 8
LENS
Lens Mount
Focal Length
FOCUSING
Type
Coverage
AF working range
AF Modes
One Shot
Servo AF
AF Point Selection
Spot AF
AF Lock
AF Assist Beam
Manual Focus
Selected on lens
EXPOSURE CONTROL
Metering modes
AE Lock
AEB
ISO Sensitivity [8]
Type
Speed
Shutter Release
WHITE BALANCE
Type
Settings
1. Blue/Amber +/-9
WB Bracketing
VIEWFINDER
Type
Dot count
2.36 Million dots
Approx. 100%
Magnification
Approx. 0.70x [1]
Eyepoint
Eyepiece shutter
N/A
LCD MONITOR
Type
Coverage
Approx. 100%
