Abe R Ration
Leading Member
But you'd have to enlarge the smaller wall to the same output size so your analogy fails.If I paint two walls, one larger than the other, I have to use more paint on the larger wall. Because its bigger. But the total amount of paint doesn't determine the quality of the paint job.
But you observed them at different enlargements.Yes I used more paint on the bigger wall, but it is spread out across a bigger area, too.
If you take a picture with a large format camera and a iPhone, and you decide to compare the output, do you print the iPhone image to 4,8 mm by 3,6 mm and the large format image to 254mm by 203mm and then compare from the same distance?
Would that make any sense to you?
How about comparing the same output size?
So with the same exposure an iPhone and Pentax 645D have identical image quality, same DoF on the same ouput sized image and so on?Light and sensors/film work the same way. A bigger sensor absorbs more light for the same exposure, because the light has to be spread out across a larger area.
Really?
The science of photography is about information. Here are simple facts:
The carriers of information are photons. Photons play by the rules of quantum mechanics and the flow of photons follows Poisson distribution. For poisson distribution standard deviation (or noise) is the square root of the number of photons. Thus the more photons are collected, the larger the signal to noise ratio will be. With the same exposure parameters (scene luminance, aperture number, exposure time) the larger the image, the more photons are collected, thus the higher SNR.
Sensor doesn't reproduce anything. The lens draws an image and the sensor samples it.Correct exposure means that the sensor reproduces the real-life image faithfully
I understand perfectly what exposure is. Scene luminance, aperture number, exposure time. Exposure does not care about image circle size or sensor format or focal length or aperture diameter. However how the image appears does care about those things.(let's define it that way) without losing shadow or highlight details. A smaller sensor collects less total light, but that light is spread across a smaller area, so that exposure is the same and our subject is reproduced correctly.
What is "correct exposure" however one wants to define it is not at all relevant to this context.
And no one has claimed there is. So why you keep on briging this up?Anyone who has used a standalone light meter can tell you that there isn't a format adjustment.
How about reading what I write before answering?
ISO is not a part of exposure. Maybe you should check out how it's defined as it would tell you that it can not be.It measures the light and tells you what ISO setting, aperture, and shutter speed combination will provide correct exposure.
And "correct exposure" is largely subjective and absolutely irrevant to this topic and context.
Indeed. And I've tried to teach you what those are but you keep on sidestepping to exposure being the same for all formats which is true, but irrelevant to this topic.Now, there are certainly a host of other effects from changing format.
When you change the format, but keep exposure the same (along with framing and focus point) you change noise, depth of field and depth of focus. (We can ignore the last of those in this context.) I am happy to provide you with relevant formulas to calculate relevant numbers for different formats if you're interested.
Not really. Maybe you should try to understand noise before talking about it. Try the Emil Martinec article. Or if you don't trust a physics professor, I can point you out to blog of a dude who teaches image sensor designers.And digital noise is influenced by sneers size
Ok, please explain photon shot noise to me and how it influences the image and output image?, just like grain was influenced by film size. But trying to say that "total light" means a thing is just simply bullhonky.
Or is it just nonsense, scientific mumbojumbo?
