marcelpres
New member
- Messages
- 5
- Reaction score
- 0
Hi All,
After some days of googling and trying myself without success I decided to share my issues with you even if I am sure parts of it have been already diascussed / answered previously here.
I am kind of new in photography and having difficulties with RAW processing softwares, specially color profiles.
What I want is a pretty simple workflow for developing my RAWs with a free tool on Mac (Linux compatibility is an advantage, I don't care Windows): finetuning lights, contrast, maybe some lens / perspective correction, B/W, but no retouching, no magic with colors.
Basically the best would be starting the development with some kind of sw preset applied on the RAW image matching the embedded JPEG. I know it is not the professional way, but I think I have not enough experience and not enough time to start building every image from scratch.
Based on my previous experience and reading articles I found four sw candidates. All of them are producing very different results ater importing the same RAW file specially in case of colors and I think this is because different color profiles and/or differently handling existing color profiles (even possible?). See below my conclusion. Points starting with (!!!) are the most important ones which discourage me from using the software.
but not sure still why these softwares show different result in color while using the same input color profile.
What should I do?
In the third case there is no technical limitation, softwares are corssplatform and having tons of features, but when it comes to color I can not produce satisfying images.
Sorry for the long post, any comment / suggestion is appreciated even for color profiles or RAW processors above.
Marton
- NX Studio
- Obvious choice for my old Nikon camera
- Matching the embedded JPEG automatically and most precisely.
- A bit unconfortable, lack of ergonomics
- (!!!) Slow and unstable. Takes forever to launch, very slow behaviour during development and has a very serious memory leak problem. It can often eat all of the system memory and then freeze.
- There is a Color management tab in Options menu but I am not sure how to use input, and output profiles. Only choice called "RGB default profile" is set to "Nikon sRGB 4.0.0.3002". I think that is the output profile.
- Exported JPEG looks just like in the editor. Having "Nikon sRGB 4.0.0.3002" color profile.
- Not available for Linux
- Apple Photos
- Easy and fast to use on Mac
- Does not reproduce exactly the embedded JPEG but to my eyes this is the closest to reality, good colors, contrast, lights etc. Some magic here, maybe MacOS does this since it is the same look as seen in 3rd party image viewer when I open the same RAW file. But definatelly I do not know what is happening.
- Not so powerful like the two below, but would be enough for me.
- (!!!) Incompetent in file handling. Following the usual apple "style" it does not allow to see / store / copy the image files and sidecar files. I just import images into my library and then the whole image set is stored in one big file. Impssoble to move to another computer (maybe it is with iCloud subscription). I can export JPEG and even the RAW file untouched but that way I will lose all modifications on the RAW file, there is no sidecar files.
- Does not have any color profile setting, I am almost sure it is using Apple's "Display P3" as input profile and something called "sRGB linear" as output profile.
- Exported JPEG looks just like in the editor. Having "sRGB linear" color profile.
- Not available for Linux.
- Darktable
- Speed and ergonomy is OK, but not a native app for Mac.
- Maybe the most similar to Lightroom (?).
- Tons of possibilities, some of that are not so straightforward.
- (!!!) After importing RAW image, it is exactly what I meant by "from scratch". Ugly grey image without contrast and color. With built-in color profiles I gave up after 30 minutes of tweaking. I could not get closer even to the JPEG look. Colors were far from reality. Then I tried the same but now using color profiles stolen from other softwares like Apple Photos or Adobe DNG converter. As a result, colors are much closer to reality or at least the JPEG look but still slightly different and the image is still dark and is lacking of contrast that should be fixed using curves I guess, which seems too complicated and time consuming compaired to starting with JPEG look.
- Input and working color profile can be specified, default value is something called "standard color matrix" which gives better result than other built-ins but still not good enough.
- Does not handle dcm profiles, only icc profiles.
- Exported JPEG looks just like in the editor. Having "sRGB IEC61966-2.1" color profile.
- Availble for Linux
- Rawtherapee
- Even more tons of possibilities, most of those are understandable.
- (!!!) At the beginning imported RAW image is just like in Darktable explained above, but here I have better possibilities for fixing it. Curves seem to work better to me, more understandable workflow and there are usable automations for tone curves but at the end color still does not match with embedded JPEG or what I remember as reality or what I can see when I open the RAW file with a simple image viewer even with sRGB profile which is used in NX studio or with Display P3 profile which is used in Apple Photos.
- (!!!) Exported JPEG has less color and contrast compared to the editor look. Having "sRGB IEC61966-2.1" color profile or whatever I chose as output, but the result is the same. I think it could be fixed somehow but I also gave up after several hours of reading and trying.
- Input, working and output color profile can be specified, there is a lot of built-in. icc and also dcp profiles can be used.
What should I do?
- With NX Studio: live together with the unstable and slow software, have more attention to in-camera JPEG image processing settings since these are affecting the embedded JPEG which will be the starting point in RAW processing?
- With Apple Photos: forget thinking about files, live together with dependence on MacOS and the risk of losing all the development ever done on RAW images, just export JPEGs and store unmodified RAWs?
- With Darktable or RawTherapee: Keep trying to get a better undersanding of way of working of each software and color profiles, keep trying to understand why using same color profiles gives different color result, maybe create a custom preset holding all the fixes which can lead from the ugly uncolored dark image to close to the JPEG look and use this preset all the time?
Marton
