My working color space is ProPhoto RGB, I save my edited master file in ProPhoto RGB. For print I naturally soft proof for my printer/paper profile.
All widely used browsers are now color managed so for the web you can use any space you want. This allows people with wide gamut monitors to see the image as close as you intended.
For the web my choice of output color space depends on the image. Images with strong reds/yellows are posted in PCI-P3. Images with a wide variety of greens/blues are posted in Adobe RGB. sRGB only for images that the colors of the image as I want it to appear can fit in the sRGB gamut. I naturally also soft proof in the final output color space.
Kind regards
Kaj
http://www.pbase.com/kaj_e
WSSA member #13
It's about time we started to take photography seriously and treat it as a hobby.- Elliott Erwitt
Thanks. How do you see ProPhoto RGB? What is the percent coverage on your monitor?
There are no monitors that can display ProPhoto RGB. It actually even covers "colors" that the human eye cannot see. But it allows me to not lose any info when editing retain all the information in the RAW. The soft proof converts the file to colors that fit the output profile. You have to watch the RGB histogram and avoid blowing any colors too much and selecting the visually best rendering intent.
My monitors cover Adobe RGB and DCI-P3.
I have also sometimes used rec. 2020 color space as a working space, which covers practically all printable colors. It is a color space that probably will become a standard for monitors as technology advances.
I am confused how this works. Your working color space is ProPhoto however you cannot display what you are working on?
That's a valid point. But if you work only with the colors your monitors can display you will loose a lot of the colors you can see and that can be printed. When working within RGB you are never allowed to blow any colors, but the histogram will guide you any how. With experience you will learn to interpret it..
When you edit a master file the purpose is to maintain all the colors that your printer/papers, and all the colors monitors can display for any future need. That is why it is good to have you working space in a gamut that covers all your potential uses. You save your edited master file in a wide gamut where you try to not loose any colors. Then when you print or display for for the web you soft proof your image to suit the output media.
No monitor or print can display all the colors you can see. No printer can print all the colors of sRGB, Adobe RGB or DCI-P3. If you want a master file that can be used to generate the best file for any output media you need a very wide gamut as a working space to arrive at any future use.
The 1931 CiE xy diagram is a depiction of all the colors you can see. None of the present color gamuts can cover all of them not even ProPhoto RGB, even if it also has a narrow range of non-colors that a human cannot see.
A useful concept is the so called Pointer's gamut which contains all the surface colors (colors reflected from a surface or any color that in theory can be printed).
This link provides a good overview of color spaces and Pointer's gamut:
https://tftcentral.co.uk/articles/pointers_gamut
A gamut close to the ideal for printing is Rec. 2020 it covers practically all the printable colors, if you do not want to use Pr0Photo RGB. Adobe Camera Raw already provides Rec, 2020 as a possible color space, but it is not available in Photoshop as a default working space yet.
Lightroom uses ProPhoto RGB as a working space (actually something nicknamed Melissa RGB which is ProPhoto RGB with a gamma of 1.8 , fi they have not changed it recently to actual ProPhoto RGB). Lightroom allows other profiles only when you soft proof and output for your selected media.
