Alan_W1
Hello all,
I need some confirmation regarding my Latitude setting on my ioptron base.
After capturing encouraging first results of the moon, using my longest/heaviest telephoto gear, plonked on top of a video head and tripod, i have decided to build a wedge for it, to slightly increase the versatility of that set-up, for static lunar use {and hopefully Jupiter etc} in my little west-facing backyard {not for mobile situations}....therefore i probably only require a basic polar alignment, as i am not using motors to guide, but do need to manually tweak the image occasionally, to keep it more in position within the frame...as it moves across {to avoid major cropping when shooting for stacking purposes}.
I had thought of getting a second-hand EQ mount off Ebay for my largest set-up, but i don't want to spend too much cash for a limited use....especially as i would be over the payload limit for an EQ3-2....and a more suitable EQ5 would not be worthwhile for my limited situations {i have too much gear as it is}.
My Ioptron Skyguider Pro is ideal for my mobile/lightweight set-up, of short/medium lens gear, but not suitable for the big stuff....therefore a wedge option with my video head seems worth a shot.
I have yet to use the Ioptron yet {lack of clear enough skies to view Polaris, since owning it}, so have set my latitude on the grid at my 54.3' degrees location {marked with the red arrow}, but i am unsure if that is correct, as i would have expected the top of the grid to have 90 degrees instead of 0 degrees. Therefore i can't get my head around whether i have set it correctly, or it should be set at 35.7' degrees {from the top} on this specific grid.
I have cobbled together this wedge, which i have lined-up with the elevation of the ioptron base latitude setting, but have not fully locked it down permanently/securely yet {for a general polar alignment}...until i can confirm my latitude has been set correctly on the ioptron.
Any help or confirmation is appreciated. I'm sure it is a simple answer, but my old brain is getting older by the second.
cheers.
cheers.
