John Crellin
Forum Enthusiast
Didn't proof read my text, apologies. By "bottom" I meant left.
Oh and I see I then went on to use confusing words like above - by which I meant to the right - above in the sense of brighter or to the right. In a sense there isn't much important information in a histogram in the up/down direction as far as I can see - apart from whether there are any pixels at a particular luminance at all.
Should have left it to the glossary reference :-(
But the point I was trying to make in the final bit is that I do find the D70 will often tend to leave space at the bright or right end of the plot if the dynamic range is low - which I am sure is what leads to all the worry about dull results. All it needs is a tweak in the curves control but it happens.
This should read "cuts off on the left hand side". The histogramIf it cuts off at the bottom you have lost some detail down in the
shadows and will get black for parts of the picture - no D70 frame
to show you where this is (unless I missed something !)
is a plot of the number of pixels (vertical scale) for each
luminance value (horizontal scale).
Changing the exposure will move the whole graph left or right, notAs a secondary function, if there is space above the plot with
nothing in it then the D70 has underexposed and, if you don't want
to post-process, then try again with more exposure. But in my
experience this only happens when the range of the scene is low and
you haven't actually lost anything but you will get the famous D70
dull picture without post - processing !
up or down. If the histogram ends a quarter of the way from the
right hand edge but runs up to the left hand edge with lots of
pixels there, then you have probably underexposed.
Bob Meyers
