Hello, all:
I'm looking for a better (and portable, not built-in) solution to holding overhead lighting, such as 1 or 2 monolights - one with reflector, one with a medium softbox. Pretty heavy (12-24 pounds)
Currently, I need two heavy duty booms/stands with counterweights to do this (Bogen 3119/3071's) weighing about 70 lbs. total. Alot to tote.
What I was considering, is finding or building a tubular steel, telescoping crossbar that can be hung between two heavy-duty backdrop supports or lightstands or existing boomstands.
My thought was to create a fairly rigid (compared to aluminum) 3-section tubular steel crossbar out of 1-1/4 inch, 5 foot telescoping antenna mast sections, pinned together with two 1/4 inch bolts for positive locking. I'd then attach two Bogen 123 pivoting boom clamps to mount lights on and hang the contraption from two stands. Overall, the crossbar would be 8 or 12 feet long (I'd cut down the mast sections and use only as many sections as needed on each shoot) and would need to support 12-24 pounds of lighting while remaining safe & stable.
The resulting boom with clamps would not weight more than about 10 pounds, and I'd get to reuse my existing stands. If I use backdrop stands, total setup weight would be about 25 lbs, a savings (to my back) of 45 pounds - no counterweights needed, either.
So... any suggestions or comments? Is there a commercial solution to this problem? I'm handy with tools & fabrication, but would prefer a prepackaged solution.
Thanks for your input!
Brian C.
Brian C.
