I personally don't believe you'll find anything with a kit lens better than the G1-X.krugman wrote:
Could posters provide a list of these for under $ 1500 including kit lens?
Just curious.
Krugman
Go to DxoMark and pick any Canon Rebel and compare it to the G1X (my favorite is 100D). Much better with much less sluggishness.krugman wrote:
Just curious.
Krugman
The IQ of the 100D with kit lens doesn't match the G1-X, at least mine doesn't anyway.Catalin Stavaru wrote:
Just curious.
Krugman
Just curious.
Krugman
Not really true, the newest m4/3's camera have nearly a stop more dynamic range, a touch more colour depth (not noticeably different) and very similar high ISO performance to the 70D. Other things come into play like colour preference (which I prefer on the Canons) but m4/3's does have the edge. I had the OMD E-M5 and it has better dynamic range than my 5D2 at base ISO.KLinLA wrote:
Most any modernish Canon DSLR can be better than G1X, but you'd need something other than a kit lens. Adding something like a 17-55mm f2.8 to a DSLR body could be done for around the $1500 you mentioned. I believe, but not certain, this is true for EOS M as well.
You could also consider one of the mirrorless/m43 if smaller size is important. A micro 4-3rds with Lumix 14-42 pancake is roughly similar/smaller size, but IMHO still slightly poorer IQ.
But you'd get better responsiveness (faster focus) and have flexibility of different lens combos.
If you are willing to consider camera with fixed and non-zoom lens, a Fuji X100S would be similar to G1X IQ wise, and might even be better to some eyes.
Just curious.
Krugman
Yes G1X has slightly poorer DR. Here, I was referring to overall image quality with regards to m43 bodies with the Lumix 14-42mm pancake lens.papillon_65 wrote:
You can pick up an E-M5 for a decent price now the E-M1 is out.
No, all Canon APS-C bodies have poorer DR than the newer M4/3's bodies, do you want me to show you? it's very easy to prove. The G1-X has just under a stop less dynamic range than the 70D, that's why I use ND grads on it when I need to, it usually solves the problem. Of course you can also change lenses on any m4/3's camera and APS-C DSLR, which is the main reason for going that route.KLinLA wrote:
But that's a 2 year old camera. Better ones come out all the time. And who knows if sony is going to kill their nex line in favor of alphas and their a3000 style camera.Kevin Coppalotti wrote:
In december 2011 this is what dp review said about the sony nex7:
Here are two that I believe would put the G1-X to shame in both IQ and lens flexibility for less than $1300 with Kit fixed lens:papillon_65 wrote:
Krugman
How on earth could you know how good (or bad) the RX10 is ? for a start it has a smaller sensor and a longer range so I very much doubt it will put the G1-X "to shame", or even match in the range of the G-1X. Of course the GX7 and 20mm will perform well but then you need to buy at least one more lens to match the range of the G-1X and if it's one of the m4/3's kit lenses then it won't match the lens on the G1-X in my experience. I have a Canon 5D2 and several lenses and that doesn't put the G1-X "to shame" at all, in fact often it's a lot closer than you would think and that's a full frame camera with a very decent sensor.tron555 wrote:
Here are two that I believe would put the G1-X to shame in both IQ and lens flexibility for less than $1300 with Kit lenses:papillon_65 wrote:
Krugman
http://www.dpreview.com/news/2013/1...sony-cyber-shot-rx10-first-impressions-review (talk about a quality and versatile fixed lens camera!!!)
AND, there is always the GX7 if you are really interested in getting a quality system camera.
http://www.dpreview.com/products/Panasonic/slrs/panasonic_dmcgx7
AND, with the GX7, you can put any quality/focal length lens you want on it for any situation!
Growing old is inevitable, Growing up is optional!
The RX10 has the same sensor that the RX100 II has, and it IS a great sensor and 20MP vs 14MP.How on earth could you know how good (or bad) the RX10 is ? for a start it has a smaller sensor and a longer range so I very much doubt it will put the G1-X "to shame", or even match in the range of the G-1X. Of course the GX7 and 20mm will perform well but then you need to buy at least one more lens to match the range of the G-1X and if it's one of the m4/3's kit lenses then it won't match the lens on the G1-X in my experience. I have a Canon 5D2 and several lenses and that doesn't put the G1-X "to shame" at all, in fact often it's a lot closer than you would think and that's a full frame camera with a very decent sensor.
And you think lens speed is all that counts? The G1-X sensor is significantly larger than the RX-10 so by your logic the G1-X "blows away" the RX-10. The performance of the lens on the G1-X is excellent all the way through the range, the longer the lens the harder that is to achieve. Of course by your own melodramatic description the G1-X clearly "blows away the RX-10", whose performance you don't even know about yet. I couldn't say either way except to say that the G1-X won't be "blown away" unless Sony have managed to defy the laws of physics ;-)tron555 wrote:
The lens on the RX10 has a 24–200 mm, F2.8 over the entire focal range vs a 28–112 mm, F2.8 - F5.8 lens. So, the lens on the RX10 completely blows the G1X lens away!
"much more superior"? try the the GX7 with any m4/3's kit lens against the G1-X and I can guarantee it won't be "much more superior". Differences in performance either way are marginal at best.Then, there is the much more superior GX7 that will accommodate just about ANY focal length lens you would like have. All you need to do is decide which focal length(s) you want to have and at what quality you can afford. However, this is a system camera that will take you to that next level if you are prepared to go there. If you are not at that stage yet, the RX10 would be more practical.
Not really, I just don't use such hyperbole as "blows away" and "much more superior" when in reality the differences are more about what the format can do as opposed to some kind of mythical performance. I leave such hyperbole to fans of WWF and yourself ;-)PS, if your Canon 5D2 and several (expensive) lenses do not put the G1X to shame, you should really consider getting rid of them ;-)
OK, now I’m going to have to prove my point, sorry if I go over your head or get too technical for you:papillon_65 wrote:
I never said to compare the GX7 with only it’s “kit lens”, try the 12-35 and 35-100 Panasonic zoom lenses that cover a focal range of 24-200mm range with a constant f2.8 aperture!!! Do you think that combination would out do the G1X in both IQ and lens quality? This should be interesting;-)"much more superior"? try the the GX7 with any m4/3's kit lens against the G1-X and I can guarantee it won't be "much more superior". Differences in performance either way are marginal at best.
The price of a GX7 with the 12-35 lens it quite a bit out of the original poster's stated price range.I never said to compare the GX7 with only it’s “kit lens”, try the 12-35 and 35-100 Panasonic zoom lenses that cover a focal range of 24-200mm range with a constant f2.8 aperture!!! Do you think that combination would out do the G1X in both IQ and lens quality? This should be interesting;-)
