Balance in Composition - the basics.
ianbramham
Manchester, UK
Jeri raised some issues a while ago on this forum that made me think more about the so-called compositional rules that get quoted so much.
Personally I believe that composition is all about achieving good balance in the rectangle of the viewfinder and that there are a host of different ways in which the elements of the photo can be arranged so that they look harmonious.
As an architect I've been dealing with issues such as aesthetic balance in building design, light & shade, colour and tone all my adult life so I tend to trust my instincts when composing a photo in the viewfinder, however I would imagine that there will be members of the forum who have spent all their lives in a scientific background rather than an artistic one and who may be struggling with some of the basics.
One of things I learnt when I was still a student was that proportion and composition in architecture are closely linked to the basic principles of maths and music so this got me wondering if there was a logical way to explain some of the basics of composition to the more mathematical minded members of the forum who are new to photography and the whole issue of compositional balance.
As a student of architecture we also had to learn how to design basic reinforced concrete beams and the like and it occurred to me that simple force diagrams hold strong links with some of the principles of balance that I subconsciously use when I'm looking through the viewfinder.
Taken to the extremes of simplicity the principles are the same as those of a seesaw and I've done a few sketches to illustrate what I mean.
Before I explain further it's important to realise that, like a seesaw, the plumb center of the photo is a hot spot around which all balance in the composition of the photo revolves.
Everyone understands the basic idea behind a seesaw as in the sketch above...if you have two people of equal weight they need to be equidistant from the center fulcrum, however it is also possible to balance the seesaw with two people of widely differing sizes and weights by making the larger one sit closer to the fulcrum as in the sketch below.
The same principles of balance apply exactly when you are composing a photo if you think of the centre of the image as being the fulcrum about which the differing elements need to balance out in their visual weight and importance within the overall image.....generally speaking the futher an element in a photo is away from the centre the more power it holds so a smaller element on the edge of the frame can counter balance a larger one nearer to the center.
This is how the idea might apply in a photo:
This idea is not just limited to the fundamental size of the object but also it's colour and tone....a small vivid, red or yellow coloured object in an otherwise plain image can balance out a much larger lesser coloured one elsewhere in the frame. Likewise in mono photos the depth of tones of the objects are fundamental to their importance and 'weight' within the overall image.
In the sketch below a dark coloured small strip of sea might balance out a larger strip of pale misty sky at the top of the image and you can see how the simple principles of the seesaw are starting to get interesting:
Obviously these same principles apply in the 3D view we get through our viewfinders with the object of balancing out elements between foreground and distance .....hence why so many professional landscape photographers go on so much about the importance of balancing a good vista with a nice foreground.
I looked through my laptop to see if I could find a few of my photos that I could use to illustrate the idea and I'd welcome feedback from anyone who thinks this is a useful first step to approaching balance in composition.
http://ianbramham.aminus3.com/
http://photo.net/photos/ian.bramham
... this made my brain hurt. LOL But thank you for taking the time trying to explain things to me and others who are interested. If I can just learn a teensy bit of what you do, then I'm happy. :)
Ian,
as a mathematician (and former engineer), I appreciate your idea of balance. In physics it is a very simple idea of force/momentum/etc equilibrium that runs thru the second seesaw drawing you did.
This applies very well to the second group of drawings. And it goes horizontally, vertically, diagonally and also includes size/volume.
The idea that math plays a role in art is as old as both endeavours. I recommend for those interest the book
The Science of Art: Optical Themes in Western Art from Brunelleschi to Seurat (Paperback)
by Martin Kemp (Author)
It has a very nice initial chapter on perspective and projective geometry including the work of Brunelleschi, the starter of it all.
But back to your post: I really think you should develop that into a full-fledged concept and publish it. I'm not sure, but I haven't seen it before, as you've articulated it, even if some of the ideas sure permeate most of formal classical aesthetics.
I'd love to help you with the math if you need anything.
best, Renato.
Regards, Renato.
http://www.flickr.com/photos/11435304@N04
OnExposure member
http://www.onexposure.net/
OK Professor Ian… I’ll take a stab… But I need a cupa first… :-)
1st photo – This one is not as obvious – yet you choose it first – interesting… You have a ton of rules going on in this photo – except your horizon line is dead center. But, this works because both the top and the bottom have quite a lot going on, so balance is achieved.
2nd photo. I love this one. The balance is more obvious though – in fact, it is everywhere in this pic. The large cloud upper left balanced against the large structure bottom right – and they over lap at the middle point of the seesaw. Also the texture is balanced – the rough bricks sort of mimic the grain in the clouds.
  1. 3 – Not as easy as I thought it would be. Once again you have your horizon almost dead center – do you do this a lot? I’ll have to start watching for this. This is balanced for sure, though I’m having trouble figuring out why. The bridge is a very strong element and I don’t think the water on the left would be enough to balance it by it’s self, so it must be the fact that the clouds on that side are stronger than on the right – therefore the strong clouds + the large body of water = bridge.
  1. 4. I always enjoy seeing this one. A very special photo indeed. I wonder though… would it be even more powerful if the figure on the left was all alone? Once again the center horizon line is almost centered. Interesting. :-) But, this one is obvious where the balance is concerned. The smaller figure is further away so it holds more power and therefore balances the larger figure that is closer.
(grin) – I don’t know if this is what you had in mind, but it was a great exercise for me. I want to thank you for all the time you took to put this together - I will remember this when I shoot and PP. :-)
(After thought) Ian – balance is super important, you just proved that. But your photos contain just as much emotion as balance. How are you going to teach me that??? :-)
Jeri
Don't worry about making a mistake - - as long as you learn from it.
I was just about to reply when Jeri's response popped up, so I'll tag onto this.
Its a great principle, far better than the standard garb people throw around which does nothing but mislead people into irrelevances. Balance if a fundamental concept of imagery - and unlike other compositional devices, an image will work if balanced, and can be said to work because it has balance. I was trying to avoid the rule which should not be spoke - but a composition never worked BECAUSE it uses the rule of ... sorry, I can't write it.
The maths of balance is simple in basic theory, and the seesaw demonstrates it well. However, I think the transfer to images isn't a straightforward. The maths gets very complicated the moment you introduce emotion in a subject. Take a look at this image. Its butchered to hell as a crude example of principles - hope MtnM doesn't mind me adding it to this thread, but it fits rather well.
Now I find this one demonstrates quite clearly how the emotional attachment of the bird in flight can balance a shed load of trees on the other side (notice my crude repositioning overlooked the reflection of the bird, oops). Straight maths would struggle with that one as the density of the bird in the image is no greater than the trees, but our brains automatically assign it with a strong visual value. Some would attribute this composition to the unnamed rule - but it has nothing to do with it, the bird and trees are the composition, not the bird alone.
Glad you posted this one. The first rendition of it had a very crude featureless Kate in the foreground, and though the sky was visually stunning, the boat was a lifeless black mass. This one has that essential life, and balance is restored. Nice shot. Quite complex. How much do we apply subconscious knowledge to the way the ropes hold the boats in shot? Maybe not at all, but clone out the ropes and the composition would be quite different.
Interesting how Jeri latches onto a more obvious balance here. I don't! There is so much mass to the right, that dark dark sky and huge lighthouse. I do like the image, but I find it totally dependent on the textures and tones rather than a visual balance.
†his is a hugely complex image. I've studied this one closely before, and can't for the life of me explain its success. I've not managed to apply any rational analysis to the composition - I mentioned when you first posted it that I found it lacked a subject, to which you bounced back with this amazing interpretation. Interesting again that Jeri points to the horizon being almost dead centre. Almost is a very important word here, I think it is significantly off centre... though how important is that, and how much would it change if it were dead? The only balance I can begin to argue is the deck structure to upper right balanced by the cloud reflection towards the bottom left - which makes it more ying yang... which is another fascinating compositional concept. It could well be the key to its success.
I think the key to this one is the rake. Clone it out, and you'd need to recrop it. Yet clone out the rake and the man above and it would balance.
Just post a pic of a cake. Cakes = emotion.
Jeri
http://www.flickr.com/photos/leechypics/
Make your own mind up - there are no rules in this game.
Ian, thank you for taking the time to conceive and present this. I found it very helpful. I think I already understood this on some instinctive level. Thank you for putting it into words and images that make it easy to understand and apply to our photography.
Dean Rachwitz
Nikon D80, SB-600
Nikkor 18-55VR, 70-300VR, 50 1.8
Tokina 400 5.6
Canon SD870IS
Ian,
I was intrigued by your explanation. I have just started photography, so you should take what I say a little bit lighthearted. I have just ordered a book on composition, since what I have thusfar is more focused on the technical side of photography.
As a rule of fist I have always translated compositional rules to: you should always have a clear subject. So on the beach, either the sand is the subject or the cloud, but not both. So the horizon is "never" in the middle. Equivalent: in communication there is always one main message, never more.
Having a single subject however is boring, and especially its interaction/relation with other subjects define the essence of the main subject. What is a bridge without water? Hence the balance appears. (Or a surprise or desillusion if the river is empty. But that is also an interesting emotion.)
I would tend to explain composition much more in rules of psychology. Or maybe some physiological aspects (the different neurons in our eye reacting to different colours in certain ways, thereby "liking" or "disliking" certain colour combinations). It would be interesting to see how you eyes would scan your photos, and if we can learn something from that. The emotions you have of seeing a bridge or a certain colour are much more difficult to find though.
It would seem quite possible that certain psychological processes lead to certain mathematical rules (golden section) or photographic rules (near, middle, far).
Hmm.
Adriaan
Within landscape painting (and presumably photography), the horizon line is traditionally at 1/3, 1/2, or 2/3. The composition still depends on other elements, of course, but this is a traditional composition that he presents. All were nicely balanced in my opinion.
... to read again with more time. Thank you ever so much for all the effort. At a glance it looks as interesting as the great images that accompany the copy.
Lito
D80 + Mac :)
Bombing for peace is the same as f_ g for virginity
Adriaan
I love bringing psychology into the mix. I believe the rules exist due to psychological reasons and I think I will be a better photographer for understanding these.
But, for the record, I also believe the more artistic work often breaks these rules. :-)
John – I think the image would stand alone without the bird – so the balance is already there. I would argue that the bird adds the emotion. No?
Jeri,
Thanks for your reaction. I remember a story from my musical teacher that Mozart loved to take musical turns in his music which the people in his time never expected. But now, we are so used to the music of Mozart, we are not surprised anymore!
Adriaan
Nice thread, you did a nice job of explaining this in layman's terms, good read.
Hi Ian,
This is a great topic, and put across very well.
As a designer by trade, I completely understand where you're coming from - but I would argue that your insight is just one of many aspects in image composition (balance) that make a shot work.
As others have mentioned, there are elements of emotion and psychology to consider, and from a designers viewpoint, I like the aspects of tolerance (reading into an image - from the instant subject through to the smaller details, and what a viewer 'reads' into this), and the use of imagery in page layouts for printed media (usually I have to incorporate typography onto/around an image to retain balance).
I can see a great book/website coming together, exploring all these elements of photography/image making - which would be a great resource for aspiring photographers looking for a place to learn something they may never have considered before.
I would also suggest you approach a few photo magazine editors to see if they're interested in publishing what you have just written (including responses) - as it would be a shame to see this post gradually fade into forum memory.
Look forward to seeing what you got up to in France when you get back.
Take care,
Ian
I've got too much to do tonight to respond properly to all the repiles that have come in up to now as I'm off to france on holiday with my family very early in the morning - if it's alright with you guys I'd like to pick this thread up again briefly when I get back in 2 weeks. In the meantime I'm really looking forward to the break (and the rare chance for some serious tripod work with long exposures at dusk on the beach on the Ile De Re!)
I saw this idea as a very simplistic beginning into understanding some of the basics of composition rather than being a complete guide. Like anything in life the more you understand something the more you realise you have to learn.
All the best,
Ian
