Olyjohn
Active member
If you are using any of the lenses with the lens function switch and MF clutch, you can get the same or similar) effect by just using SAF on the desired point, and then press the lens function switch to either stop AF, or change to MF. For me,this has the benefit of keeping the focus point in the viewfinder, whereas if you have to switch to MF initially that is lost. Or have I missed something?
Regards, John
Regards, John
